Limit on nrf.send() (esp32)
Jessica Morgan
Post by Jessica Morgan » Mon May 11, 2020 5:58 pm
I have a project on 2 esp32's with nrf24l01. I use the nrf24l01 library which can be found here https://github.com/micropython/micropyt ... s/nrf24l01
It works like a charm until I want to send 4 integers instead of 3 using nrf.send()
I have following code on master side
import utime
#https://github.com/micropython/micropython/tree/master/drivers/nrf24l01
import sys
import ustruct as struct
import utime
from nrf24l01 import NRF24L01
from micropython import const
# Slave pause between receiving data and checking for further packets.
_RX_POLL_DELAY = const(15)
# Slave pauses an additional _SLAVE_SEND_DELAY ms after receiving data and before
# transmitting to allow the (remote) master time to get into receive mode. The
# master may be a slow device. Value tested with Pyboard, ESP32 and ESP8266.
_SLAVE_SEND_DELAY = const(10)
cfg = {"spi": -1, "miso": 19, "mosi": 23, "sck": 18, "csn": 5, "ce": 4}
#http://electroniqueamateur.blogspot.com/2019/12/communication-nrf24l01-avec-cartes.html?m=0
# Addresses are in little-endian format. They correspond to big-endian
# 0xf0f0f0f0e1, 0xf0f0f0f0d2
pipes = (b"\xe1\xf0\xf0\xf0\xf0", b"\xd2\xf0\xf0\xf0\xf0")
# Parameters and global variables
# Pin definitions
sda_pin = machine.Pin(21)
scl_pin = machine.Pin(22)
# Create an I2C object out of our SDA and SCL pin objects
i2c = machine.I2C(sda=sda_pin, scl=scl_pin)
# TMP102 address on the I2C bus
tmp102_addr = 0x48
# TMP102 register addresses
reg_temp = 0x00
reg_config = 0x01
pakketnr = 0
# Functions
# Read temperature registers and calculate Celsius
def read_temp():
    return 221;
def updatePakketnr():
  global pakketnr
  pakketnr +=  1
  if (pakketnr >= 3600):
    pakketnr = 0
  return pakketnr
# Initialize communications with the TMP102
def init():
    # Read CONFIG register (2 bytes) and convert to integer list
    val = i2c.readfrom_mem(tmp102_addr, reg_config, 2)
    val = list(val)
    # Set to 4 Hz sampling (CR1, CR0 = 0b10)
    val1 = val1 & 0b00111111
    val1 = val1 | (0b10 << 6)
    # Write 4 Hz sampling back to CONFIG
    i2c.writeto_mem(tmp102_addr, reg_config, bytearray(val))
def readSendTemp():
    csn = Pin(cfg["csn"], mode=Pin.OUT, value=1)
    ce = Pin(cfg["ce"], mode=Pin.OUT, value=0)
    if cfg["spi"] == -1:
        spi = SPI(-1, sck=Pin(cfg["sck"]), mosi=Pin(cfg["mosi"]), miso=Pin(cfg["miso"]))
        nrf = NRF24L01(spi, csn, ce, payload_size=12)
        nrf = NRF24L01(SPI(cfg["spi"]), csn, ce, payload_size=12)
    nrf.open_tx_pipe(pipes[0])
    nrf.open_rx_pipe(1, pipes[1])
    nrf.start_listening()
    print("NRF24L01 master mode")
        # stop listening and send packet
        nrf.stop_listening()
        temperature = read_temp()
        preamble = 0xAA
        counterBit = 0
        for bit in bin(temperature):
          counterBit +=1
        counterBit -= 2
        numberOfBytes = int(counterBit / 8)
        updatePakketnr()
        print("sending:",preamble,numberOfBytes,int(temperature*100))
            nrf.send(struct.pack("iiii",preamble,numberOfBytes,pakketnr,temperature))
            print("sent")
        except OSError:
            pass
        utime.sleep(5)
def readout():
    # Read temperature and print it to the console
    print(round(temperature, 2))
    utime.sleep(1)
readSendTemp()
and following on slave side
import sys
import utime
"""import machine
import sys
import utime
"""Test for nrf24l01 module.  Portable between MicroPython targets."""
import sys
import utime
# Pin definitions
tmp102_addr = 0x48
reg_temp = 0x00
reg_config = 0x01
def slave():
    nrf.open_tx_pipe(pipes[1])
    nrf.open_rx_pipe(1, pipes[0])
    print("NRF24L01 slave mode, waiting for packets(ctrl-C to stop)")
        if nrf.any():
            while nrf.any():
                buf = nrf.recv()
                recieved = struct.unpack("iiii", buf)
                preamble = recieved[0]
                numberOfBytes = recieved[1]
                temp = recieved[2]/100.0
                print("preamble",hex(preamble),"numberofbytes",numberOfBytes,"temperature", temp)
                utime.sleep_ms(_RX_POLL_DELAY)
slave()
These are build using as starting place nrf24l01test.py (see link)
Now I was wondering is there a limit in the send function ? Or is there something else going wrong? (maybe with the struct.pack() )
I tried sending 4 constants too. But that doesn't seem to help either
Thanks a lot already
Jessica Morgan
Re: Limit on nrf.send() (esp32)
Post by Jessica Morgan » Tue May 12, 2020 9:06 pm
Turns out my payload was too low. After putting, it higher (32) sending 4 integers worked too
