I have a need to connect multiple (4-6) thermocouple to either a pyboard or a Wipy board and I was hoping to use the MAX31850K 1-wire breakout board listed here:
https://www.adafruit.com/products/1727
I read in the forum that there was some work done on a 1-wire library but that it may have a bug preventing the use of multiple 1-wire device, discussion here:
http://forum.micropython.org/viewtopic.php?t=345
If anyone has knowledge of this (or other) 1-wire library current state I would appreciate the update.
Jim
1-wire protovol
Re: 1-wire protovol
The official 1-wire driver found at https://github.com/micropython/micropyt ... onewire.py works on the pyboard an supports multiple 1-wire devices on the same wire.
There is also a driver for the DS18x20 temp sensors at https://github.com/micropython/micropyt ... ds18x20.py which supports multiple sensors on the single wire.
I looks like you can use the DS18x20 driver for the MAX31850 with a small change to the way the temperature is calculated from the raw value.
Re: 1-wire protovol
I now have the MAX31850 working with the pyboard. The changes to the ds18x20.py driver were minimal. If anyone is interested in the project I will upload the MAX31850 driver.
Re: 1-wire protovol
Just put it on Github and post the link here. That way somebody can still find if they come here later, even if you're not active on the forum anymore.
Re: 1-wire protovol
Where can I get the max31850 python library mentioned above?
