Windows 8.1 driver installation failure
satya369
Post by satya369 » Tue Aug 18, 2015 3:54 am
I am using a Windows 8.1 laptop 64 bit. I tired to follow the procedure on the Wiki to install drivers for Win 8.1.
http://forum.micropython.org/viewtopic.php?t=100
http://wiki.micropython.org/Installation
But I was unsuccessful. Can someone tell me whats wrong?
See the attachment. It is the screen shot for the failure message.
Failure message.jpg (35.06 KiB) Viewed 2845 times
platforma
Re: Windows 8.1 driver installation failure
Post by platforma » Tue Aug 18, 2015 12:49 pm
Sounds like you selected a folder.
Did you click the "Have disk" button?
Once you did, navigate to the "pybcdc.inf" file and select that and not the folder it is located in.
satya369
Post by satya369 » Tue Aug 18, 2015 3:24 pm
Yes. I did select the file "pybcdc.inf" but still got the error message. I will retry it and let you know.
satya369
Post by satya369 » Wed Aug 19, 2015 1:42 am
I tried this multiple time but still having the same issue.
I have another PC which is a Windows 7 PC and I was able to install drivers successfully. But for some reason its failing on Windows 8.1
stijn
Post by stijn » Wed Aug 19, 2015 7:52 am
You could try replacing all occurrences of the 'NTamd64' string in the inf file with 'NTamd64.6.3' so it targets windows 8.1 specifically.
platforma
Post by platforma » Wed Aug 19, 2015 4:30 pm
stijn wrote:You could try replacing all occurrences of the 'NTamd64' string in the inf file with 'NTamd64.6.3' so it targets windows 8.1 specifically.
While that is a hack, it might actually work. But the inf file should already take care of that, I don't have a copy of it though.
In the same article, there is "More information can be found here" that might be of help as well.
