Support for low power modes (Pyboard 1.x and D)
Posted: Fri Oct 02, 2020 3:34 pm
I have updated my micropython-micropower repo to provide full support for the Pyboard D. The module provides easy access to the following hardware features:
In the case of the D series there is one exception. There is a firmware bug in the Pyboard D identified by @irsla which prevents the pin wakeup working. Pin wakeup requires firmware built using the above PR.
The Tamper mechanism does work with official firmware; unfortunately this pin (X18/C13) is only brought out on the wbus and WBUS_DIP68 adaptor.
- 4KiB of backup RAM accessible as words or bytes. May be battery backed. Whether or not battery backed, retains data during standby.
- 20 general purpose 32-bit registers also battery backed.
- Wakeup from standby by means of a switch on the Tamper pin.
- Wakeup from standby by means of two Pyboard pins (four on the D series).
- Wakeup by means of two independent real time clock (RTC) alarms. An alarm provides for (say) a wakeup every the 1st day of the month at 03:15.
- The ability to determine the reason for wakeup from standby.
- Support for the stop condition. This stops the time source used by utime. The module provides alternative ways to do millisecond level timing via the RTC.
