uPing - Ping library for MicroPython
shawwwn
Post by shawwwn » Fri Sep 21, 2018 10:08 am
MicroPython implementation of ICMP Ping.
Works exactly like linux's ping command.
https://gist.github.com/shawwwn/91cc897 ... 34c38195fb
Example:
>>> import uping
>>> uping.ping('google.com')
PING google.com (64.233.185.138): 64 data bytes
84 bytes from 64.233.185.138: icmp_seq=1, ttl=40, time=71.636004 ms
84 bytes from 64.233.185.138: icmp_seq=2, ttl=40, time=70.365000 ms
84 bytes from 64.233.185.138: icmp_seq=3, ttl=40, time=71.599998 ms
84 bytes from 64.233.185.138: icmp_seq=4, ttl=40, time=82.879000 ms
4 packets transmitted, 4 packets received
(4, 4)
Usage:
uping.ping(host, count=4, timeout=5000, interval=10, quiet=False, size=64)
  • @host: host's domain name or ip address to ping.
  • @count: how many packets to send
  • @timeout: stop if not receiving anything within a certain time period (milliseconds)
  • @interval: time between sending each packet
  • @quiet: suppress print messages
  • @size: ICMP packet size (bytes), must > 16
  • @return: tuple(number of packet transmitted, number of packets received)
Re: uPing - Ping library for MicroPython
Post by pythoncoder » Sat Sep 22, 2018 4:34 am
Very useful!
A couple of points about the code. PEP 8 suggests indenting by 4 spaces. Tabs carry hazards (notably the case where an invisible space creeps in and causes indentation errors) so are generally not recommended.
On the plus side I've been writing Python for donkey's years and it never occurred to me to write
not quiet and print('something')
Neat!
shawwwn
Post by shawwwn » Sat Sep 22, 2018 7:57 am
Just changed. Thanks!
KJM
Post by KJM » Sun Nov 18, 2018 11:02 pm
I can't get this to run on a pycom gpy. File "/flash/lib/uping.py", line 46, in ping AttributeError: 'function' object has no attribute 'randint' which I fudged with h.id=100 as a workaround
then File "/flash/lib/uping.py", line 51, in ping AttributeError: 'module' object has no attribute 'SOCK_RAW' which I'm not smart enough to fix.
I'm grief stricken! I could so use a pinger on this platform. Thoughts anyone on a fix?
Post by pythoncoder » Mon Nov 19, 2018 6:41 am
If you're running the Pycom fork I can only think that this fork lacks some useful features. You may be able to work round the randint issue with uos.urandom(4) with suitable conversion to an integer. FWIW the value of usocket.SOCK_RAW is 3 but if the underlying implementation is absent from their fork I'm afraid your only option is to talk nicely to Pycom.
More and more of the issues in this forum are down to variations between forks/ports :(
HermannSW
Post by HermannSW » Mon Nov 19, 2018 4:49 pm
The randint issue only occurs on my ESP8266, not on the ESP32.
This little diff fixes it:
$ diff uping.py.orig uping.py
45c45,46
<     h.id = urandom.randint(0, 65535)
>     urandom.seed(utime.ticks_us())
>     h.id = urandom.getrandbits(16)
But with that change both ESP modules run into index error:
>>> uping.ping("woogle.de")
  File "uping.py", line 53, in ping
IndexError: list index out of range
Last line here is it:
$ head -53 uping.py | tail -9
    h.seq = 1
    # init socket
    sock = usocket.socket(usocket.AF_INET, usocket.SOCK_RAW, 1)
    sock.setblocking(0)
    sock.settimeout(timeout/1000)
    addr = usocket.getaddrinfo(host, 1)[0][-1][0] # ip address
P.S:
I inserted "print(usocket.getaddrinfo(host, 1))", empty list explains error
>>> uping.ping("google.de")
  File "uping.py", line 54, in ping
>>> ### closed ###
P.P.S:
My fault, modules were AP only with no internet connection.
Now I made station active as well:
>>> usocket.getaddrinfo("google.de",1)[0][-1][0]
'172.217.20.131'
But now uping.py errors out on line 50 (socket init, ESP8266 module):
  File "uping.py", line 50, in ping
OSError: [Errno 22] EINVAL
What is wrong with this simple statement on 1.9.4 ESP8266 MicroPython?
johncblacker
Post by johncblacker » Tue Jan 08, 2019 8:35 pm
Running into a problem trying to run uping.ping('192.168.0.2')
I get:
File "uping.py", line 49, in ping
OSError: [Errno 22] Invalid argument
Tried again:
>>> import usocket
Doesn't like that socket create statment...
johncblacker
Post by johncblacker » Tue Jan 08, 2019 8:53 pm
experimenting a little and found that it definitely doesn't like "usocket.SOCK_RAW"; however, I can print usocket.SOCK_RAW and get an output value of 3...
pmp-p
Post by pmp-p » Sat Jan 19, 2019 2:15 pm
@johncblacker: more likely it's the 1 it does not like, as IPPROTO_ICMP is probably not handled on various ports.
