Thonny autocomplete issue
CmdrDeLiver
Post by CmdrDeLiver » Fri Dec 06, 2019 6:45 pm
So I searched high and low for a good IDE. Thonny 3.2.3 looks like the trick so I installed it and wow, it looked nice. I'm hitting issues with autocomplete however for ESP8266.
Installed 3.2.3 for linux 64 bit. Installation and Setup instructions used are here.
Open Thonny > Tools > Open System Shell>
pip3 uninstall jedi
pip3 install jedi
Now autocomplete works with the board based REPL for imported items. Attempting autocomplete for anything not imported pops the same errors repeatedly in a modal dialog, then dumps them to the REPL session:
error NoneType.png (44.66 KiB) Viewed 12495 times
Autocomplete is non-responsive in the code editor. Hitting tab might as well be routed to Null.
Any suggestions for resolving these issues?
Thanks,
Mike
aivarannamaa
Re: Thonny autocomplete issue
Post by aivarannamaa » Mon Dec 09, 2019 10:01 am
Hi!
adzierzanowski recently fixed the shell autocomplete bug in 3.2.4.
I could not reproduce the editor completion problem in 3.2.4. Can you post the code and position where you tried autocomplete?
BTW. I recommend reporting this kind of issues right in Thonny's issue tracker -- most likely you'll get response sooner this way.
Aivar
(Thonny's author)
Aivar Annamaa
https://thonny.org
CmdrDeLiver
Post by CmdrDeLiver » Mon Dec 09, 2019 5:30 pm
Aivar,
I think I'm on 3.2.3. I'll update and post an issue if the problem continues.
Thanks,
Mike
CmdrDeLiver
Post by CmdrDeLiver » Mon Dec 09, 2019 5:47 pm
Aivar,
3.2.4 is vastly better. I'll open a ticket for the error I'm still able to reproduce...
New file, save as 'something.py'
Type imp and hit tab pops up dialog "Autocomplete Error" : "Autocomplete Error"
However:
import os
os. (hit tab)
... now works as expected in both editor and REPL.
Thanks,
Mike
