I would like to write a C library for interfacing a micropyton command.
In C something like this (of course, the types are wrong ...)
STATIC mp_obj_t myLibrary_call(mp_obj_t array_obj) {
uint32_t i;
for (i = 0; i < 10; i++) {
array_obj = i;
In micropyton, something like this :
buffer = [0] * 10
print(buffer)
0 0 0 0 0 0 0 0 0 0
myLibrary.call(buffer)
print(buffer)
0 1 2 3 4 5 6 7 8 9
In the package I found some examples that use to pass simple integers (but no arrays).
Any suggestion to help me to write the C & micropython code for this simple array example?
Thank you
efr
Simple MicroPython to C interface
Re: Simple MicroPython to C interface
In general, given an mp_obj_t you need to check its type and then convert it to the type you're expecting (e.g. MP_OBJ_TO_PTR).
But in this case, to extract the bytes out of any type supporting the buffer protocol, you want to use mp_get_buffer_raise() or similar:
mp_buffer_info_t bufinfo = {0};
mp_get_buffer_raise(my_obj, &bufinfo, MP_BUFFER_READ);
// Now you can use bufinfo.len and bufinfo.buf
Hi Jimmo,
Great, thank's for this useful information.
I will check this immediately
Regards
efr
Regards
efr
