Automate command lines that use rshell
Alqx
Post by Alqx » Wed Mar 10, 2021 1:03 pm
Hi the micropython community,
I encountered a problem using rshell :( . In fact, I am on windows 10 and I am using a batch file to automate command lines (4 lines in all). The 3 rd line involves the rshell. Only here, once I am correctly connected to the rshell, the last line is not carried out.
Do you know why ? If yes, how to fix it?
I leave you a screenshot attached.
Here are the command line:
d: #in order to connect to the correct disk
python CAMERA.py #run a python script using the webcam
rshell #in order to connect to the pyboard
repl ~ exec(open('motor.py').read()) ~ #run a script on the pyboard allowing to run motors
Thank you in advance for your help!
Best regards,
TROESTLER Grégoire, student in preparatory class for engineering schools.
Re: Automate command lines that use rshell
Post by dhylands » Wed Mar 10, 2021 11:32 pm
You should be putting the repl command on the same line as the rshell commnad. So:
rshell repl "~ exec(open('motor.py').read()) ~"
Normally, I would use import rather than exec. i.e. use:
rshell repl "~ import motor ~"
I'm not exactly sure about the quotes when using windows, but they're definitely need on Mac/Linux.
The way you've show things, rshell will be launched and once you press Control-D to exit, it will then resume running the script and probably produce an error because it doesn't know what the repl command is. For example, I created hello.py with the following contents:
print('Hello World')
print('Sleeping for 10 seconds')
time.sleep(10)
print('After sleep')
and running this shows:
$ rshell 'repl ~ import hello ~'
Connecting to /dev/cu.usbmodem3389337E34332 (buffer-size 512)...
Trying to connect to REPL  connected
Retrieving sysname ... pyboard
Testing if sys.stdin.buffer exists ... Y
Retrieving root directories ... /flash/
Setting time ... Mar 10, 2021 15:35:27
Evaluating board_name ... pyboard
Retrieving time epoch ... Jan 01, 2000
/Users/davehylands/micropython/upy-examples> Entering REPL. Use Control-X to exit.
MicroPython v1.12-210-g1993c8c-dirty on 2020-02-29; PYBv1.1 with STM32F405RG
>>> import hello
Hello World
Alqx
Post by Alqx » Thu Mar 11, 2021 6:09 pm
Hi Dave,
Thanks a million !! :D
It works !
(And just to let you know: the command works also without quotes on windows )
