Onewire scan question
Wim
Post by Wim » Thu Mar 11, 2021 1:08 pm
Hello all,
i am playing a bit with micropython and a ds18b20 i use the following short program:
import onewire, ds18x20
# the device is on B12
dat = Pin('B12')
# create the onewire object
ds = ds18x20.DS18X20(onewire.OneWire(dat))
print('found devices:', roms)
rom_code = roms[0]
print(ds.read_temp(rom_code), end=' ')
print()
print (rom_code)
for i in range(8):
    print (hex(rom_code[i]) , end=' ')
The program works ok and reads the temperature fine but i do not understand why i only get 7 bytes back from ds.scan() but when i read them back seperate i get 8 bytes .
The output of the program is:
found devices: [bytearray(b'(\x82\x9b\x94\x05\x00\x00\x87')]
19.0
0x28 0x82 0x9b 0x94 0x5 0x0 0x0 0x87
I am using MicroPython v1.14-82-gcdaec0dca on 2021-02-27; WeAct F411CE with STM32F411CE
Regards
Wim
Re: Onewire scan question
Post by dhylands » Thu Mar 11, 2021 2:27 pm
You are getting back 8 bytes. The first byte (after the quote) is an opening parenthesis ( which has a hex representation of 0x28.
When python tries to print a string it will use ASCII bytes whenever possible and only uses hex values for non-ASCII bytes.
Wim
Post by Wim » Thu Mar 11, 2021 3:03 pm
Now i see it it is the second ( before the /x82.
I overlooked a parenthesis i should have counted them :oops:
Thanks a lot.
Wim
