Is there an easy way to make the pushbutton() function run asynchronously? I was looking at https://github.com/peterhinch/micropython-async but it seems somewhat overkill for my purpose.
#import, pin out defs & html code removed for brevity
def pushbutton():
relay.value(1)
time.sleep(1)
relay.value(0)
return
def waitforconn(w):
count=0
while not w.isconnected() and count < 10:
print('Reconnecting')
time.sleep(5)
count += 1
return w.isconnected()
#Reconnect to wifi with 10 retries
def do_connect():
maxtries=10
if not wlan.active():
wlan.active(True)
wlan.connect()
waitforconn(w=wlan)
if not wlan.isconnected():
raise NameError('WIFI failed')
print('network config:', wlan.ifconfig())
def sendhtml(conn, response):
conn.send(b'HTTP/1.1 200 OK\r\n')
conn.send(b'Content-Type: text/html; encoding=utf8\r\nContent-Length: ')
conn.send(str(len(response)))
conn.send(b'\r\nConnection: close\r\n\r\n')
conn.sendall(response)
conn.close()
return
#Start simple server
s = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
s.setsockopt(socket.SOL_SOCKET, socket.SO_REUSEADDR, 1)
s.bind(('', 80))
s.listen(5)
startrelay=time.time()
if gc.mem_free() < 102000:
gc.collect()
print("Not connected...")
do_connect()
conn, addr = s.accept()
print('Got a connection from %s' % str(addr))
request = conn.recv(1024)
header=request[0:3].decode()
if header.find('GET') >= 0:
temp = [i.strip() for i in request.decode('utf-8').split('\r\n')]
method, uri, proto=temp[0].split(' ')
if 'HTTP' in proto:
page_req=uri.split('?')
get_arr=page_req[1].split('&') if (len(page_req) > 1) else []
if uri.find("/pushbutton") >= 0:
now=time.time()
if ( now - startrelay > 4 ) :
print('Relay button push')
startrelay = now
pushbutton()
else :
print('Block relay button push')
conn.send(b'HTTP/1.1 200 OK\r\n\r\n')
conn.close()
response = html # contains html of page
size = len(html)
conn.send(str(size))
# Send response
conn.sendall(html)
conn.close()
response = 'Error: Not a http connection ({})'.format(proto)
print(response)
sendhtml(conn=conn, response="<html><head>Error</head><body><p>{}<p></body></html>".format(response))
# Send response
response = 'Error: Not a GET request ({})'.format(request[0:3].decode())
print(response)
print(request.decode('utf-8'))
except OSError as e:
gc.collect()
text = str(e)
print('Connection closed: {}'.format(text))
conn.close()
if 'WIFI' in text:
print('Do reboot')
time.sleep(120)
machine.reset()
