DHT11: InvalidPulseCount: Expected 84 but got 76 pulses
Re: DHT11: InvalidPulseCount: Expected 84 but got 76 pulses
Post by Roberthh » Fri Nov 05, 2021 1:18 pm
You could try to change lines 162, 163 from
                humidity=value[0] & 0x7f
                temperature=value[2]
to
                humidity = (value[0] & 0x7f) + value[1] / 10.0
                temperature = value[2] + value[3] / 10.0
According to the data sheet, that should be right. But it may be, that this data in value[1] and value[3] is always 0, in which case you get a float out of this setting with the decimal being 0 all the time. The standard driver does not use this nmbers as well. In case that you sensor is actually a DHT22 model, you should change the call.
Komfibrot
Post by Komfibrot » Mon Nov 08, 2021 8:45 am
Thank you, I changed the Line 135 & 136 according to your new code and I get float values. thank you!
Now I get no further questions about it. You helped me a lot!
