Micropython Display To Pc Screen
Re: Micropython Display To Pc Screen
Post by Roberthh » Mon May 09, 2022 2:01 pm
@Zcannon78 It seems that they pyboard requires a firmware update. In older firmware version, the module was called uos. In newer versions, you can both use os and uos.
Zcannon78
Post by Zcannon78 » Mon May 09, 2022 8:53 pm
What I ended up doing was using a TTL USB/UART module and connected the UART pins on the pyboard to the module. I then used the Pyserial library on my Pc to send encoded messages to UART(1) (COM4/TTL module), which were decoded by the Pyboard and vice versa. In the end I was able to have my tkinter program send and recieve data and change the state of the pyboard. I’m not sure if it was the best way to do it, but it works.
Zcannon78
Post by Zcannon78 » Mon May 09, 2022 8:57 pm
RSC Games wrote:
Mon May 09, 2022 1:45 pm
Did you by chance upload a file called "boot.py" or "main.py" and put a while loop in it?
I don’t think so. The command didn’t work in REPL either.
Zcannon78
Post by Zcannon78 » Mon May 09, 2022 9:00 pm
I don’t think that would be the case. I updated my pyboard a few days ago and the os command worked previously.
cgglzpy
Post by cgglzpy » Tue May 10, 2022 2:52 pm
@cgglzpy I tried out the upydevice library but my experience was inconsistent. I have been able to turn on and off the built-in leds and read the directories once. After I had uploaded different programs to the pyboard, the upydevice program stopped communicating with the pyboard and I had to reset. When I factory reset the pyboard, I tried to read the directory files again and it gave me the error NameError: name 'os' isn't defined. Although I could still turn on and off the leds.
@Zcannon78 if you reset the pyboard you need to import os module before calling
os.listdir()
otherwise it will throw that error.
So you need to add
import os
in boot.py or main.py or do
import os; os.listdir()
for this to work every time.
as @RSC Games said a while loop will block the REPL which is necessary for upydevice to work. You can break the while loop sending a keyboard interrupt/ CTRL-C character with e.g.
device.kbi()
wangshujun@tom.com
Post by wangshujun@tom.com » Mon May 23, 2022 2:18 am
You can take a look at the implementation of openmv, which contains the code to display the internal cache to the IDE. Openmv is an extended implementation of micro python, which should be more promising for transplantation
