Simple terminal (VT100) editor widget (and other widgets)
Re: Simple terminal (VT100) editor widget
Post by Roberthh » Thu Oct 22, 2015 4:30 pm
@mbirth
Hello, and thanks for the visit. Sorry for the confusion, but I think you see complications where there aren't any.
The only file you need is pye.py. It contains the full code of the text editor based on pfalcons Edit widgets. You can run pye.py on any platforn with python3 and a vt100/xterm console, like linux or OS X like any other text editor (e.g. nano, gedit). You would simple issue the command:
python3 pye.py filename
Micropython works too, if you install micropython-lib (https://github.com/micropython/micropython-lib). pye.py runs on pyboard too. A command sequence would be:
from pye install *
pye("filename")  or pye(list_of_strings)
The file pye.py contains special sections to deal with the I/O interfaces of linux, PyBoard and WiPy. To separate them, they start with:
if sys.platform == "PyBoard".
or the like. Without that, python would raise an error, when the code is executed on the other platforms. The file pye.py contains C-Preprocessor statements, which allow variants of the file for specific platforms, like.
cpp -D LINUX pye.py | grep -v "^# .*$" >pex.py
cpp -D PYBOARD pye.py | grep -v "^# .*$" >peb.py
cpp -D BASIC -D WIPY -D DEFINES pye.py | sed "s/#.*$//" | sed "/^$/d" >wipye.py
The removes the sections for the other platforms, but still keep the "if sys.platform == ..." statements, which do not hurt. The last example is mandatory for WiPy due its restricted memory size. WiPy would not parse the full pye.py code. The -D DEFINES replaces the symbolic key names by numeric constants, and the -D BASIC excludes some of the features. I have seen other ways to achieve that, but for me it works. The shebang file consist of a single line as the first line in the python script:
#!/usr/bin/env python3
which tells the linux bash or csh to use python3 to run pye.py. It's not included by default since cpp cannot deall with it.
Best regard
andrew
Post by andrew » Thu Oct 22, 2015 5:38 pm
@Roberthh I'd love to try your editor on my WiPy but it seems to run out of memory even when freshly booted. Any ideas?
Login succeeded!
>>> import gc
>>> gc.mem_alloc()
2160
>>> gc.mem_free()
55232
>>> from wipye import pye
MemoryError: memory allocation failed, allocating 176 bytes
Andrew
Post by Roberthh » Thu Oct 22, 2015 7:10 pm
Hello Andrew, memory-wise it's during loading at the limit. What I see is after Ctrl-D:
PYB: soft reboot
MicroPython v1.5-1-ge954604 on 2015-10-21; WiPy with CC3200
>>> import gc
>>> gc.mem_alloc()
1264
>>> gc.mem_free()
55072
>>> from wipye import *
>>> gc.mem_free()
42336
It's only critical during loading. After that, I could load & edit the file wipye.py itself, which is like 450 lines.
Just for an attempt, try deleting some code. In the function handle_edit_key, there are sequences like elif key == 0x... Each of them handles a single function. 0x09 is Tab, 0x15 is backtab, 0x18, 0x04 and 0x16 are the buffer functions, and so on... For trial, you can remove any of them. You can also delete the functions scroll_up() and scroll_down() and any calls to them. They are only called once each in wipye. That makes scrolling slower, but saves a few hundred bytes.
I know that the recent Version of MicroPython works better, since sometime in the last two weeks, the memory allocation stuff was improved. And be sure that you use the version of wipye.py generated by the strip.sh script.
Regards, Robert
Post by Roberthh » Fri Oct 23, 2015 7:12 am
@andrew
I handcrafted a smaller version of wipye, just as a trial. It's attached. It has like 70 lines less of code and consumes 3k less in memory. Almost all functions are still there. It seems, that the size of the source code is more the limiting factor than the parsed memory footprint. I do not know the internals of the language parsing, which makes size optimization kind of a blind flight. What I found interesting is that each function adds about 400 bytes in memory. I might reduce the number of small & rarely called functions.
Robert
wipye_small.zip
(3.36 KiB) Downloaded 602 times
andrew
Post by andrew » Fri Oct 23, 2015 8:00 am
Roberthh wrote:@andrew
I handcrafted a smaller version of wipye, just as a trial. It's attached. It has like 70 lines less of code and consumes 3k less in memory. Almost all functions are still there. It seems, that the size of the source code is more the limiting factor than the parsed memory footprint. I do not know the internals of the language parsing, which makes size optimization kind of a blind light. What I found interesting is that each function adds about 400 bytes in memory. I might reduce the number of small & rarely called functions.
Robert
Thanks for that but for some reason it's still not working for me despite having more memory available than you show.
>>> dir()
['__name__']
>>> import gc
>>> gc.collect()
>>> gc.mem_alloc()
1424
>>> gc.mem_free()
55968
>>> gc.collect()
>>> from wipye_small import pye
MemoryError: memory allocation failed, allocating 1462 bytes
>>> dir()
['gc', '__name__']
Andrew
mbirth
Post by mbirth » Fri Oct 23, 2015 8:40 am
andrew wrote:on my WiPy but it seems to run out of memory even when freshly booted. Any ideas?
For me it loaded fine after I rewrote my main.py to use lazy imports and did a gc.collect() before trying to import wipye. mem_free was around 52-53k.
However, I was not able to do anything once it was loaded. It didn't register my key presses (was connected via miniterm.py from Linux).
pyBoard v1.0 + LCD32MKv1.0 | WiPy + Expansion Board | GitHub
andrew
Post by andrew » Fri Oct 23, 2015 8:47 am
You'll have to forgive me as I'm still new to Python. What are lazy imports?
Andrew
mbirth
Post by mbirth » Fri Oct 23, 2015 8:53 am
andrew wrote:What are lazy imports?
It's loading your libraries when they're needed instead of on top the .py file. So instead of:
import os
def whereami():
    print(os.getcwd())
You'd do it like this:
def whereami():
    import os
    print(os.getcwd())
This way, os is first imported when it's needed instead of being imported right away.
But according to your available memory readings, this shouldn't be a problem in your case.
Post by Roberthh » Fri Oct 23, 2015 9:13 am
@mbirth
Hello all. Thanks for trying.
On WiPy and PyBoard, it's not a standalone program. If you want to edit something, you have to input:
pye("filenname")
at the REPL prompt. The sequence I use is:
from wipye import *
pye("myfile")
Instead of a filename, you may also supply a list of strings. I'm using Telnet on Linux and Putty or Teraterm on Windows for a telnet connection. If you want to use the UART connection, you have to wite:
pye("filename", device=1, baud=xxxx)  # UART0 on WiPY, UART 1 on PyBoard, or
pye("filename", device=2, baud =xxxx)  # UART1 on WiPY, UART 2 on PyBoard
The default speed is 115200 Baud
@andrew
I do not know why it does not load. Did you upgrade WiPy to the latest version of the firmware? On the other hand, I have seen difficulties in the memory handler of micropythin with the Linux port, which I did not expect. I'm still trying to replicate that.
Regards
andrew
Post by andrew » Fri Oct 23, 2015 4:06 pm
Roberthh wrote: @andrew
Regards
Ah, I hadn't thought of upgrading the firmware as until yesterday my WiPy appeared to be stuck permanently in safe boot mode precluding the option. So I've just upgraded and yes, the wipye module imported and I was able to execute pye('wipye.py'). Yay! Thanks for this - it should make quick edits to scripts a lot easier.
Andrew
