Page 3 of 3
Re: pybkick - tools to make deploying code to pyboard easier
Posted: Sun Oct 26, 2014 6:02 pm
by shell
Posted: Sun Jan 03, 2016 6:11 am
by EasyRider
Newbie bump.
I have just started playing with MicroPython and have very limited knowledge of Linux and the development side of MicroPython source.
I have an applications to transfer/deploy python code to embedded remote pyboards via serial UART link.
As I understand this thread and pybkick offers the solution to serial "file" transfer and deployment. Unfortunately, I don't quiet understand the process and if pyboard needs any particular driver/library or if it needs to be placed in any particular state/mode to receive/deploy remotely transferred code. Secondly, as I am working on Win 7 PC at the moment, is it possible and how to transfer/deploy code from Win 7 host PC ? In what format (text?) should the code file be, is it same as main.py?
Would appreciate advice from original author or anyone else that may assist.
Best Regards
John
Posted: Sun Jan 03, 2016 6:19 am
by dhylands
I'm not familiar with pybkick, but I've also written a program call rshell.py which can be used to copy files into and out of the pyboard over a serial UART link or the USB serial link.
It also allows you use the repl. It still has some rough edges, but I'm also constantly improving it.
https://github.com/dhylands/upy-shell/t ... ter/rshell
It also allows you edit files on the pyboard (it copies the files to the host, invokes an editor and copies them back it any changes were made).
rshell requires no extra software to be installed on the pyboard and takes advantage of the raw-repl to perform all of its work.
Posted: Sun Jan 03, 2016 6:30 am
by EasyRider
Thanks Dave,
It's time I set up a PC with Ubuntu and will try rshell.
rshell looks fairly comprehensive too.
Best Regards
John
Posted: Sun Jan 03, 2016 7:02 am
by dhylands
For testing new code, my typical cycle looks something like this:
cd into-directory-with-source-code
2113 >rshell.py
Connecting to /dev/ttyACM0 ...
Welcome to rshell. Use Control-D to exit.
/home/dhylands/Dropbox/micropython/upy-examples> cp hello.py /flash
/home/dhylands/Dropbox/micropython/upy-examples> repl
Entering REPL. Use Control-X to exit.
MicroPython v1.5.2-dirty on 2016-01-02; PYBv1.0 with STM32F405RG
>>> import hello
Hello World
>>> <Press Control-X> to leave REPL>
/home/dhylands/Dropbox/micropython/upy-examples> <Press Up-Arrow twice to get previous cp command>
I normally edit my file using a separate editor, but that's just my habit.
rshell uses Control-X to exit the REPL (so that Control-D can still be used for a soft-reset) and uses Control-D to exit from the rshell prompt (when not at the REPL).
I also normally use the command
in my boot.py file so that the USB Mass Storage is disabled, since USB Mass Storage can often mess up files on the pyboard.
