How to interrupt an infinite loop executed by exec in a thread?
lgyer
Post by lgyer » Tue Mar 09, 2021 6:07 am
There are two problems.
One is how to terminate a thread in another thread by using _thread module?
Another problem is how to interrupt an infinite loop executed by exec in a thread? like this:
import _thread
def task1():
    print('task1 running')
    exec('while True:\n  print("task1 ~~")\n  time.sleep(1)',globals())
def task2():
   print("task2 running")
      print("task2 !")
      time.sleep(1)
_thread.start_new_thread(task1,())
_thread.start_new_thread(task2,())
When I use Ctrl+E and Ctrl+D to run this code and use Ctrl+C to stop it, it can't be terminated.
Why can Not I stop it?
CmdrDeLiver
Re: How to interrupt an infinite loop executed by exec in a thread?
Post by CmdrDeLiver » Thu Mar 11, 2021 9:37 pm
Perhaps a flag to indicate it is time to exit?
import _thread
f_run = True
def task1():
    exec('while f_run:\n  print("task1 ~~")\n  time.sleep(1)',globals())
def task2():
   while f_run:
      print("task2 !")
      time.sleep(1)
time.sleep(90)
f_run = False
You could also you an if f_run == False: break to escape at any line that suits you.
lgyer
Post by lgyer » Fri Mar 12, 2021 6:30 am
import _thread
f_run = True
def task1():
def task2():
   while f_run:
      print("task2 !")
      time.sleep(1)
time.sleep(90)
f_run = False
Hi CmdrDeLiver
Thanks for your reply.
Yes, it can work when the flag to be confirmed. But if the code was very long to execute, how to make it be interrupt immedicately? Is there any way?
CmdrDeLiver
Post by CmdrDeLiver » Fri Mar 12, 2021 2:11 pm
Hey Igyer,
This is a job for break and continue! Break exits the loop immediately. Continue forces the loop back to the beginning where the loop condition is evaluated. Both can give you finite control over your exit point.
  if f_run == False:
    break
  sleep(1)
  print("still running")
This might be helpful to understanding loop control: https://realpython.com/python-while-loop/
lgyer
Post by lgyer » Sat Mar 13, 2021 8:14 am
Hey Igyer,
  if f_run == False:
    break
  sleep(1)
Hi CmdrDeLiver,
Maybe I didn't descript my problem precisely. I know the break can make the loop stopped.
My problem is how to interrupt the loop as quick as possible ,like this:
    if f_run == False:
    	break
    balabalabala.......   # these statements could handle some tasks which may consume time very long, maybe 5s - 10s..
    sleep(10)  # like this. So the extreme case is that the f_run has been True, but it still need wait for 10 seconds, instead of exiting immediately.
CmdrDeLiver
Post by CmdrDeLiver » Sat Mar 13, 2021 3:56 pm
Have you looked at _thread.exit? I'm unsure how/if it is implemented in micropython as there is zero documentation on the wiki. You might want to go to the source and figure it out.
CODE: SELECT ALL
if f_run == False:
break
I see what you mean and there's a simple answer. You can put logic between each statement to break out. That might include turning the sleep statement into something along the lines of
for i in range(100):
    if f_run == False:
    	break
    sleep(0.1)
Check out _thread.exit() though. It might have the secret sauce you're looking for.
lgyer
Post by lgyer » Tue Mar 16, 2021 7:39 am
CODE: SELECT ALL
if f_run == False:
break
    if f_run == False:
    	break
    sleep(0.1)
Okay, thanks a lot. I'll try it. Thanks again.
