[Solved] Multiple potentiometers problem (ESP32)
Posted: Fri Mar 19, 2021 10:52 pm
by macrimarco001
Hello Guys, this is the second topic i post... i have to say that i think this is a very helpful and productive community since i found someone so kind who helped me unstuck from another problem.
Unfortunately for me i need once again your help.
I tried connecting two potentiometers to the ESP32 board ad wrote a simple code to try to read them and print the values.
The problem is that the output displayed is not what i expect... in fact one of the values is always stuck on the highest value.
I tried swapping the potentiometers and nothing new happens. I also tried to reverse the order of the readings and it works but just for the first reading i do, the other one is stuck as well.
What should i do to solve my problem?
Thanks for your kind attention and sorry for my low english knowledge.
ps. i will attach the code down here.
pot1 = ADC(Pin(35))
pot1.atten(ADC.ATTN_11DB)
print(pot1.read())
pot2 = ADC(Pin(32))
pot2.atten(ADC.ATTN_11DB)
print(pot2.read())
OUTPUT:
371 #ok
4095 #not ok
Re: Multiple potentiometers problem (ESP32)
Posted: Fri Mar 19, 2021 11:04 pm
by davef
Pin
ADC1_CH6 34 IP, no pull-up
ADC1_CH7 35 IP, no pull-up
ADC1_CH4 32
ADC1_CH5 33
Check to see if there is a channel parameter that you need to call. Looks like pin 32 and 35 are both on ADC1
Posted: Fri Mar 19, 2021 11:17 pm
by macrimarco001
davef wrote: ↑Fri Mar 19, 2021 11:04 pm
Pin
ADC1_CH4 32
ADC1_CH5 33
I do not understand... what should I check? They are separate pins and channels. Could you explain a little bit better please?
Posted: Sat Mar 20, 2021 2:15 am
by davef
Looks like you have followed the example in the docs correctly.
class machine.ADC(id)
Access the ADC associated with a source identified by id. This id may be an integer (usually specifying a channel number), a Pin object, or other value supported by the underlying machine.
I thought you would need to specify the channel, but I now understand that you can call the specific channel using "a Pin object".
pin32 works good for me, I only need one ADC input so can't help further.
Good luck
Posted: Sat Mar 20, 2021 6:16 am
by davef
It might help to tell us what hardware you are using. Maybe, pin32 has an external pull-up resistor.
Posted: Sat Mar 20, 2021 7:30 am
by OlivierLenoir
If you refer to
this document, you can improve reading by adding 0.1µF capacitor and / or sampling the ADC reading.
A code to sample the ADC reading.
def read_adc(adc_pin, sample=24):
cumul = 0
for _ in range(sample):
cumul += acd_pin.read()
return cumul // sample
# default 24 sample
pot1 = ADC(Pin(35))
print(read_adc(pot1))
# 64 sample
pot2 = ADC(Pin(32))
print(read_adc(pot2, 64))
Posted: Sat Mar 20, 2021 11:31 am
by macrimarco001
OlivierLenoir wrote: ↑Sat Mar 20, 2021 7:30 am
If you refer to
cumul = 0
# default 24 sample
pot1 = ADC(Pin(35))
# 64 sample
pot2 = ADC(Pin(32))
thank you all for the replies guys...
my hardware is:
https://www.amazon.it/Hseamall-Potenzio ... ics&sr=1-5
https://www.amazon.it/gp/product/B071P9 ... UTF8&psc=1
I tried Mr Oliver's code and found something more strange:
if I put any code (even mine) in a while cycle, even for just one potentiometer, the output has the first reading correct, but the other ones jump at maximum.
i'll put a screenshot and a photo of my board and connectoins.
Maybe by solving this deep problem we'll be able to solve the other via domino effect, at least i hope so.
from time import sleep
def read_adc(pin, sample=24):
cumul = 0
cumul += ADC(Pin(pin)).read()
while 1:
print(read_adc(35))
sleep(1)
OUTPUT:
3999 OK
4095 NOT OK
4095 ...
4095 ...
4095 ...
4095 ...
4095 ...
Posted: Sat Mar 20, 2021 12:34 pm
by OlivierLenoir
There is a small mistake on you code. You forget to declare the ADC pin. You should do this one.
cumul = 0
# default 24 sample
pot1 = ADC(Pin(35))
while 1:
sleep(1)
Posted: Sun Mar 21, 2021 8:26 pm
by macrimarco001
Hello guys, my father found the solution to the problem... and to tell dthe truth i am a bit embarassed by the mistake i made. it turned out that, since there are two ground pins on the board, i connected my ground to the wrong pin... now both potentiometers work well.
Thank you guys anyway for the help and support
Re: [Solved] Multiple potentiometers problem (ESP32)
Posted: Mon Mar 22, 2021 9:45 am
Ah, I should have spotted that in your photo. That pin has caught me out too. The silkscreen label is actually
cmd but it's very easy to misread it as
gnd.
See
pinout diagram.
