libesphttpd bindings for MicroPython
jkent
Post by jkent » Fri Mar 26, 2021 9:48 pm
Hi, I've been working on MicroPython C bindings for libesphttpd, which is in the middle of a rewrite. Part of the design involves route callbacks, and I'm currently dealing with a panic when running native python code when accessing a C object. Basically, I can use print() in my callback, but if I use any methods on my "conn" object it crashes. Any help would be greatly appreciated. (OT: I'm still considering some design choices for libesphttpd, such as per-connection tasks. The current design uses a single task for all connections using select() with per-connection write buffers. This was a design decision made when Sprite_tm originally designed it for the esp8266.)
import http
server = http.server()
def hello_handler(conn):
    print('here!') # works
    print(conn) # works
    dir(conn) # crash!
    #conn.start_response(200)
    #conn.header('Content-Type', 'text/plain')
    #conn.end_headers()
    #conn.enqueue('Hello micropython world!')
    return http.STATUS_DONE
server.routes.insert_tail('*', hello_handler)
Here is the backtrace:
https://pastebin.com/48wt8JxS
Module source:
https://gist.github.com/jkent/c937e9e37 ... 433379779b
libesphttpd (rewrite branch):
https://github.com/jkent/libesphttpd/tree/rewrite
