machine.RTC documentation
hlovatt
Post by hlovatt » Sun Apr 11, 2021 11:22 pm
Using the latest build on a PyBoard:
MicroPython v1.14-68-gd4b45898f on 2021-02-18; PYBv1.1 with STM32F405RG
I'm having trouble with `machine.RTC`, the example given in the documentation doesn't work:
>>> import machine
>>> rtc = machine.RTC()
So far so good, but:
>>> rtc.init((2014, 5, 1, 4, 13, 0, 0, 0))
TypeError: function takes 1 positional arguments but 2 were given
and:
>>> print(rtc.now())
AttributeError: 'RTC' object has no attribute 'now'
also the available methods don't match the documentation by quite some margin:
>>> dir(rtc)
['__class__', 'calibration', 'datetime', 'info', 'init', 'wakeup']
`calibration`, `datetime`, `info`, and, `wakeup` aren't in the documentation and `init` doesn't appear to work (see above). Also the documentation mentions methods that aren't present, like `alarm`. There are no 'availability' notes in the documentation, implying that all methods in the documentation should exist.
Is there better documentation?
Thanks in advance,
Howard.
mattyt
Re: machine.RTC documentation
Post by mattyt » Mon Apr 12, 2021 2:26 am
The Pyboard predates the machine API definitions; back in the day it used the original pyb API (machine evolved to be more platform agnostic than pyb). While many of the machine API's are now available on the pyboard, RTC is only half-way there. Effectively, pyb.RTC has just been aliased to machine.RTC.
So you can read the pyb.RTC docs for info on how to use the pyboard machine.RTC.
I believe the intent is, at some point, to update the pyboard machine.RTC to match the machine.RTC documentation. Any additional methods (like, say, calibrate) can move into a platform-specific module (probably stm32 or pyboard in this case).
Hope that clarifies things!
hlovatt
Post by hlovatt » Mon Apr 12, 2021 6:42 am
@mattyt Thanks. Does that mean newer boards conform to machine.RTC?
Post by pythoncoder » Mon Apr 12, 2021 7:10 am
My advice is to use the pyb library for the Pyboard's RTC. Its documentation is correct, unlike that of machine.rtc.
All Pyboards are compatible with pyb.
hlovatt
Post by hlovatt » Wed Apr 14, 2021 4:46 am
@pythoncoder Many thanks.
