Every time the device restarts, the random number is a fixed value
lgyer
Post by lgyer » Tue Apr 27, 2021 1:12 pm
Hi guys
When I use random api to get a random number at hardware rebooting, the value is a fixed number.
Even if I use the time.ticks_ms() to set the different random seed, the value is still a fixed number.
import random
impot time
seed = time.ticks_ms() % 7
random.seed(seed)
print("{}".random.randint(1,100))
Can someone tell me why is that?
Re: Every time the device restarts, the random number is a fixed value
Post by Roberthh » Tue Apr 27, 2021 2:40 pm
There was a change recently to seed the rng with more random value on boot. Which board and firmware version do you use?
lgyer
Post by lgyer » Wed Apr 28, 2021 2:02 am
Hi Roberthh
My board is ESP32 and firmware version is v1.12. Could you tell me how to fix this problem? Or has the change been merged into v1.15?
Post by Roberthh » Wed Apr 28, 2021 5:42 am
Just use 1.15. The change was merged in v1.14.
lgyer
Post by lgyer » Wed Apr 28, 2021 6:22 am
Hi Roberthh
I has tried to copy the extmod/modurandom.c of v1.15 into my project, but the problem is still existing....
Is there any point I should take care?
By the way, I'm not using ctrl+D to reboot, I just turn on/off the power directly. And it's interesting that even if I execute the command "random.randint(1,12)" twice continuely, the number which I get still is same at every boot time.
Post by Roberthh » Wed Apr 28, 2021 11:25 am
It is a definition in mpconfigport.h which has to be changed. The new value is:
#define MICROPY_PY_URANDOM_SEED_INIT_FUNC (esp_random())
Post by pythoncoder » Wed Apr 28, 2021 12:36 pm
In my testing on ESP32 with current firmware, uos.urandom() is not deterministic after a power cycle.
lgyer
Post by lgyer » Thu Apr 29, 2021 2:43 am
Hi Roberthh
I really appreciate your help.
After I add that macro, it can work.
scruss
Post by scruss » Fri Apr 30, 2021 3:59 pm
just out of interest, where does the source for the random module live? The only source I can find is micropython-lib/random/random.py, which is incomplete and has no code for initializing/seeding.
Post by Roberthh » Fri Apr 30, 2021 4:09 pm
It is a built-in module. The source code is here: https://github.com/micropython/micropyt ... durandom.c
