lambda, apply, arbitrary precision
HermannSW
Post by HermannSW » Tue Apr 27, 2021 4:08 pm
Today I stumbled over this identity for Catalan numbers:
https://oeis.org/A000108
C(p+q)-C(p)*C(q) = Sum_{i=0..p-1, j=0..q-1} C(i)*C(j)*C(p+q-i-j-1). - Groux Roland, Nov 13 2009
Normally I use "bc" tool for arbitrary precision calculations, but realized that MicroPython allows for that as well. And I wanted to learn on (Micro)Python's lambda functions. Since functools module seems not available for MicroPython, I created my own "apply(range,func)" function (concatenation of tuples):
def apply(r,f):
    R=()
    for i in r:
        R += f(i),
    return R
These are the basic "bin(n,k)" and "C(n)" functions I used:
def bin(n,k):
    return 1 if k<=0 else bin(n-1,k-1) * n // k
def C(n):
    return bin(2*n,n) // (n+1)
This code computed part of above identity the imperative way:
def sigma(p,q):
    s=0
    for i in range(p):
        for j in range(q):
            s+=C(i)*C(j)*C(p+q-i-j-1)
    return s
print(sigma(11,11))
It took me a while to correctly uise lamda and sum functions to compute same value -- the "sum(apply(..." looks more like mathematical "Sum_{...}...":
def siglam(p,q):
    return sum(apply(range(p),
                     lambda i: sum(apply(range(q),
                                         lambda j: C(i)*C(j)*C(p+q-i-j-1)
print(siglam(11,11))
Finally I wanted to check that identity is valid, but stack size limited what is possible. Anyway the "tst()" function allows for nice way to pass lambda functions with two arguments. Boolean values False/True are converted to 0/1 by "sum()" function. So overall sum returning 0 means that all (negative) identities tested are valid:
def tst(n, f):
    return sum(apply(range(n+1),
                     lambda p: sum(apply(range(p+1),
                                         lambda q: f(p,q)
print(tst(8, lambda p,q: siglam(p,q) != sigma(p,q)))
print(tst(8, lambda p,q: C(p+q)-C(p)*C(q) != sigma(p,q)))
print("[bin(9+1,2)="+str(tst(8, lambda p,q: 1))+"]")
The last line tells the number of tests done in total:
MPY: soft reboot
MicroPython v1.14 on 2021-04-13; Raspberry Pi Pico with RP2040
>>> import catalan
88026769844
88026769844
0
0
[bin(9+1,2)=45]
Finaly this is complete "catalan.py":
def bin(n,k):
def C(n):
def apply(r,f):
    R=()
    for i in r:
        R += f(i),
    return R
def sigma(p,q):
    s=0
    for i in range(p):
        for j in range(q):
    return s
print(sigma(11,11))
def siglam(p,q):
def tst(n, f):
                                         lambda q: f(p,q)
Pico-W Access Point static file webserver:
https://github.com/Hermann-SW/pico-w
Tiny MicroPython robots (the PCB IS the robot platform)
viewtopic.php?f=5&t=11454
webrepl_client.py
https://github.com/Hermann-SW/webrepl#webrepl-shell
HermannSW
Re: lambda, apply, arbitrary precision
Post by HermannSW » Thu Apr 29, 2021 4:38 pm
Cosmetics, easier to read, does not use that much space horizontally, equivalent to previous code:
def siglam(p,q):
    return sum(apply(range(p), lambda i:
               sum(apply(range(q), lambda j:
webrepl_client.py
HermannSW
Post by HermannSW » Fri Apr 30, 2021 1:41 pm
This is more clean:
def siglam(p,q):
    return (apply(range(p), lambda i:
Returns nested tuples
>>> catalan.siglam2(3,2)
((14, 5), (5, 2), (4, 2))
which "sum()" cannot handle -- but "sumit()" can:
def sumit(t):
    return t if isinstance(t, (int,float)) \
      else 0 if len(t)==0                  \
      else sumit(t[0])+sumit(t[1:])
>>> catalan.sumit(catalan.siglam2(3,2))
32
"sumit()" can deal with integers and floats, and with nested tuples and lists:
>>> catalan.sumit([1, (2, 3), [4, 5.6], ([7, 8, 9, 10], 11)])
60.6
"mulit()" can simply be defined if needed for mathematical product of terms.
$ cat catalan.py
def bin(n,k):
def C(n):
def apply(r,f):
    R=()
    for i in r:
        R += f(i),
    return R
def sumit(t):
def siglam2(p,q):
print(sumit(siglam2(3,2)))
print(siglam2(3,2))
webrepl_client.py
