mpremote usage on windows
haybarry
Post by haybarry » Sun Jun 13, 2021 6:23 am
Feeling stupid, but can't run mpremote from win64 laptop target RPi PICO.
Error message
File "c:\python39\lib\site-packages\mpremote\console.py", line 145, in set_conout_mode
fdout = os.open("CONOUT$", os.O_RDWR)
NameError: name 'os' is not defined
I can import os in REPL on laptop but something is missing here.
Thanks for any help
Barry
stijn
Re: mpremote usage on windows
Post by stijn » Sun Jun 13, 2021 7:22 am
It's a bug in mpremote: it is missin an 'import os' statement. I created an issue for it: https://github.com/micropython/micropython/issues/7390
As a a workaround for now, you could open console.py and insert 'import os' on line 145. Also if that works would be great if you could leave a comment in the github issue mentioned above. Or if you find other problems; seems likely no-one used this on windows yet.
haybarry
Post by haybarry » Sun Jun 13, 2021 10:08 am
Thank you.
That gets mpremote started on windows.
Now to work out how to terminate code running on the target (RPi PICO) without terminating mpremote ....
Barry
