Feeling stupid, but can't run mpremote from win64 laptop target RPi PICO.
Error message
File "c:\python39\lib\site-packages\mpremote\console.py", line 145, in set_conout_mode
fdout = os.open("CONOUT$", os.O_RDWR)
NameError: name 'os' is not defined
I can import os in REPL on laptop but something is missing here.
Thanks for any help
Barry
mpremote usage on windows
Re: mpremote usage on windows
It's a bug in mpremote: it is missin an 'import os' statement. I created an issue for it: https://github.com/micropython/micropython/issues/7390
As a a workaround for now, you could open console.py and insert 'import os' on line 145. Also if that works would be great if you could leave a comment in the github issue mentioned above. Or if you find other problems; seems likely no-one used this on windows yet.
Thank you.
That gets mpremote started on windows.
Now to work out how to terminate code running on the target (RPi PICO) without terminating mpremote ....
Barry
Barry
