uasyncio and deepsleep after inactivity
yneptik
Post by yneptik » Thu Jun 24, 2021 2:59 pm
Good afternoon
I'am quite new to micropython and working/playing with a esp32, trying to make an automatic door opener for a chicken coop.
I plan to use an oled screen and a rotary encoder to choose the time of opening, set the date, ...
I would like to put the esp32 in deepsleep mode after a certain time of inactivity, for example 1minute.
Here is my code dealing with the motor and the switches using uasyncio :
import esp32
import uasyncio as asyncio
from primitives.switch import Switch
motPWM = machine.PWM(machine.Pin(33), freq=50)
motPWM.freq(1000)
motDir = machine.Pin(32, machine.Pin.OUT)
dutyCycle = 512 #doit etre entre 0 and 1023
openButton = machine.Pin(4, machine.Pin.IN, machine.Pin.PULL_UP)
doorHigh = machine.Pin(18, machine.Pin.IN, machine.Pin.PULL_UP)
async def startMot () :
    if not doorHigh.value() :
        motDir.value(0) #deroulement garcette
        motPWM.duty(dutyCycle)
    await asyncio.sleep(0)
async def stopMot () :
    motPWM.duty(0)
async def dummy_app() :
swOpen = Switch(openButton)
swHigh = Switch(doorHigh)
swOpen.close_func(startMot)
swHigh.close_func(stopMot)
while True :
    asyncio.run(dummy_app())
How can I have a routine? function? running in back with a timer, that timer is reset to 0 every time the open button is used (and also when the rotary encoder and its switch are used). When the timer reach 60 seconds the esp32 is put in deepsleep mode.
davef
Re: uasyncio and deepsleep after inactivity
Post by davef » Thu Jun 24, 2021 8:39 pm
Just a "heads-up". I was looking at using deepsleep on the ESP32 until I ran across a note in the datasheet errata saying that coming out of deepsleep could cause random "crashes".
I would check which revision(s) it applies to and confirm the revision of your chip.
yneptik
Post by yneptik » Mon Jun 28, 2021 5:29 am
Thank you for answer, I think about it and decided not to go in deep sleep, my system will be powered most of the time from AC network.
However there will be a backup battery in case of power outage, for that reason I'm still looking for how to have a way (using coro?) to count 1 minutes after the last human action (rotary encoder / switch action) after that minute it will put at 0 a GPIO pin that drives a transistor powering the screen.
Post by pythoncoder » Mon Jun 28, 2021 9:03 am
That is easily done. See my delay_ms class. This implements a software timer that can be retriggered (like a watchdog). So, implement one of those with a 1 minute period and a callback which turns off the transistor. Each human interaction turns the transistor on and retriggers the timer.
