urllib / urequests for Micropython
Damien
Site Admin
Re: urllib for Micropython
Post by Damien » Fri Oct 30, 2015 3:50 pm
pfalcon wrote:I thought about implementing "requests" lib work-alike instead (especially as there're talks that requests may be merged into stdlib).
+1
I would much prefer to see a urequests library for uPy than uurllib (which has too many double letters!).
pfalcon
Post by pfalcon » Fri Oct 30, 2015 3:56 pm
sock = ssl.wrap_socket(sock, ...)
# use sock as usual, set timeout, connect, bind, etc
That's an option I also had in mind, but I believe it doesn't work currently with ussl - ssl.wrap_socket() provides object with just stream interface, nothing else. I'd consider allowing to call thru to underlying socket, but then it indeed will require "educating" users that's how it should be done on wipy. Of course, people won't anticipate or remember that, so they will keep doing it otherwise, so there will be need for extensive error checking. In the end, overhead will be same or more than what I proposed, which also impose much less restrictions.
Awesome MicroPython list
lucien2k
Post by lucien2k » Fri Oct 30, 2015 4:21 pm
Pretty easy to change it to work like requests instead.
It is unlikely that we'll end up with 1 monolithic library, it'll probably end up being a bunch of separate ones so you can pick and choose the functions you need (not everyone needs auth, cookies etc. especially when it is likely just API calls).
Damien
Site Admin
Post by Damien » Fri Oct 30, 2015 4:45 pm
It does work. cc3200's ssl sockets "inheret" from normal sockets, so they do provide all the methods (eg settimeout).
pfalcon
Post by pfalcon » Fri Oct 30, 2015 5:25 pm
So that's what I mean - it may work on cc3200, and does not work on ports which use ussl module based on axTLS.
lucien2k
Post by lucien2k » Sun Nov 08, 2015 5:17 pm
I have added a first version of urequests.
Supports get, post, custom http headers, cookies, basic http auth etc. Works in a very similar way to python-requests.
Available at https://github.com/lucien2k/wipy-urllib ... equests.py
pfalcon
Re: urllib / urequests for Micropython
Post by pfalcon » Sat Nov 21, 2015 12:31 am
Absolutely minimal implementation of urlopen() is now available in micropython-lib's urllib.urequest module: https://pypi.python.org/pypi/micropytho ... b.urequest
JoePyC
Post by JoePyC » Sat Jun 11, 2016 7:51 pm
I'm fairly new to python in general so I apologize if I'm missing something obvious here but I can't seem to get the urlopen command to work at all. Just using the original example of f=urllib.urlopen('http://www.microsoft.com') or any other url in its place gives me errors:
File "/flash/lib/urllib.py", line 82, in urlopen
File "/flash/lib/urllib.py", line 25, in __init__
I also don't understand the difference between the different urequest libraries that I see. The one that's packaged with wipy-urllib-master and then further in the thread there's one that's called urequest that's slightly different. I'm just trying to use it to load json data from a url so a simple load of the url is all I need.
I've looked through documentation and all the different posts related to the micropython urllib but I don't know enough about it to figure out what's wrong.
Any guidance would be greatly appreciated.
~Joe
(I'm running a Wipy board w/expansion, OS 1.2.0 connected to my home wifi)
Post by deshipu » Sat Jun 11, 2016 9:51 pm
That error you pasted is truncated, can you post the full traceback?
JoePyC
Post by JoePyC » Sun Jun 12, 2016 8:50 pm
Sure:
OSError: 111
