PWM and ADC Class on MicroPython port for Zephyr
Yadnik
Post by Yadnik » Fri Jul 16, 2021 5:01 pm
I want to run Mickroe click boards on a custom board having Micropython application flashed on zephyr. However PWM and ADC classes are not available, so I cannot run click boards running on these protocols.It would be very helpful if someone could guide me with it.
If it is not the focus of the team now I can also try writing them and opening a pull request to the upstream MicroPython repository.
Thank you very much!!
Re: PWM and ADC Class on MicroPython port for Zephyr
Post by jimmo » Mon Jul 19, 2021 2:17 am
It's on the TODO list -- the Zephyr port is a great opportunity to massively increase the reach of MicroPython to a wide range of supported boards and platforms. However there are lots of things on the TODO list and I don't think there's any likely roadmap.
But if you're interested, PRs definitely welcome.
In particular with PWM, take a look at https://github.com/micropython/micropython/pull/7450 and for some history on ADC look at https://github.com/micropython/micropython/pull/5033
