Import library in MicroPython port for zephyr
How to import a library for the micropython port of zephyr https://github.com/micropython/micropyt ... rts/zephyr.I am trying to run various Mickroe click boards on a custom TI cc1352p based mcu board. However I am facing difficulties importing libraries. Upip does not work as the board does not have wifi support.Also ampy is not working.Can someone please suggest any alternatives.
Re: Import library in MicroPython port for zephyr
Can you provide more information about what you're doing? Are you able to successfully copy files to the onboard filesystem?
As an alternative to ampy, I recommend mpremote or rshell.
Actually I am facing problems copying files and scripts to board.I tried rshell, ampy and even IDEs like Thonny.I tried the frozen modules method as well by converting .py files to .mpy files and then pasting them in this location https://github.com/micropython/micropyt ... rts/zephyr(I have it cloned it in my system) followed by building the firmware and flashing it, however in that case as well I cannot import the library or script.Can you please guide me with this please as in the readme it is said that the zephyr port supports frozen modules.
Thank you very much!!
I have previously also had a discussion with Avair the link is here:viewtopic.php?f=15&t=10879
