Adding scripts and libraries to Board
I am not able to add scripts or libraries to my board.I am using the zephyr port of MicroPython.I have tried using ampy, rshell and even IDEs like Thonny(cant use upip as board is not networked).The only way I am able to run applications is using REPL.Can someone please confirm whether only REPL can be used for this particular port, or I am making some mistake.
Thank you very much!!
- aivarannamaa
Re: Adding scripts and libraries to Board
If you are able to connect to this board in Thonny, then you should be able to use it for installing packages as well (Tools => Manage packages). Thonny would use it's own internet connection for downloading the packages and serial connection for uploading to the device.
Have you tried it?
Have you tried it?
Aivar Annamaa
https://thonny.org
https://thonny.org
- aivarannamaa
I now noticed your message in Thonny's forum. I'm replying here, because this forum is more relevant.
It looks like Thonny is trying to write modules into the root directory of your device and fails to do so (Errno 19 ENODEV). Please tell me more information about your device -- sys.path, current directory and content of the root directory. With Pico I would query it like this:
Best regards,
Aivar
>>> import sys
>>> sys.path
['', '/lib']
>>> import uos
>>> uos.getcwd()
>>> os.listdir("/")
['lib']
Aivar
Aivar Annamaa
https://thonny.org
https://thonny.org
I get this error on following (Tools => Manage packages):
Package manager is not available for this interpreter(no absolute lib directory in sys.path)
I am using the generic Micropython interpreter.I can take the bottom shell into use by running applications on repl but cant add external libraries or scripts.
Also I don't have a generic firmware flashed I am using the zephyr port.
Even while saving main.py file onto my board I get an error like:
WARNING: Could not sync device's clock: can't import name RTC
ERROR thonny.backend: PROBLEM WITH THONNY'S BACK-END
Error Could not open file /main.py for writing, output:
[Errno 19] ENODEV
It would be very grateful if you could please help me.I had also asked this on the Thonny google group.
Thank you very much Aivar.
[Errno 19] ENODEV
The output is as follows:
>>> import sys
>>> sys.path
>>> import uos
>>> uos.getcwd()
>>> import os
>>> os.listdir("/")
>>> import sys
>>> sys.path
>>> import uos
>>> uos.getcwd()
>>> import os
>>> os.listdir("/")
- aivarannamaa
Problem writing files with Zephyr port
I haven't used Zephyr port myself, but I suspect your flash or filesystem might be misconfigured. I changed the subject of this thread - maybe someone else can recommend something.
BTW. Which device are you using?
Aivar Annamaa
https://thonny.org
https://thonny.org
I am working on a board called BeagleConnect Freedomhttps://github.com/jadonk/beagleconnect ,it is based on the TI CC1352R.I also tried doing the same for the cc1352r launchxl, using the zephyr port of MicroPython as well, however getting the same error there as before.
I think this problem exists with the zephyr port in general, as I have religiously followed all the instructions as given here https://github.com/micropython/micropyt ... /README.md .
It would be very helpful if you could suggest any alternatives or ways to get applications working as I can only access repl for currently.
It would be very helpful if you could suggest any alternatives or ways to get applications working as I can only access repl currently.
- aivarannamaa
I see that you have started your quest here: viewtopic.php?f=15&t=10852
The question Jimmo asked is crucial. I recommend you continue in that thread. Jimmo certainly knows more about this.
Aivar Annamaa
https://thonny.org
https://thonny.org
