Hi All,
uPyLoRaWAN had some issues with IRQ handling, and a fix was proposed with uasync library ver 2.
See the discussion and working solution here: https://github.com/lemariva/uPyLoRaWAN/issues/16
As uasync v2 is deprecated I'd like to use the v3, however I have no enough experience with that.
Could someone update the proposed fix with the uasync V3?
Any help appreciated!
converting lorawan lib to uasyncio version 3
Re: converting lorawan lib to uasyncio version 3
This doc in my uasyncio repo has information on porting code from V2 to V3. It is fairly straightforward.
Hi Peter,
Thanks for the guidance.
I mistakenly stated that the program uses uasyncio V2, it was written with V3
But it uses IRQ_EVENT which is deprecated and ThreadSafeFlag is the new way to go.
Still not really understand how I should modify the relevant few lines of code
If you could point me to the code in question I'll do my best to help.
Hi Peter,
With the help of examples I converted the program, it seems to work, however I am not confident if this part of the code is really doing what is expected to do.
So I appreciate your offer, please find below the whole module.
I made the relevant changes only between lines 565 and 596, framed with comments ( ####### changes...)
import utime
from machine import SPI, Pin
from encryption_aes import AES
import gc
import urandom
import ubinascii
import uasyncio as asyncio
PA_OUTPUT_RFO_PIN = 0
PA_OUTPUT_PA_BOOST_PIN = 1
# registers
REG_FIFO = 0x00
REG_OP_MODE = 0x01
REG_FRF_MSB = 0x06
REG_FRF_MID = 0x07
REG_FRF_LSB = 0x08
REG_PA_CONFIG = 0x09
REG_LNA = 0x0C
REG_FIFO_ADDR_PTR = 0x0D
REG_FIFO_TX_BASE_ADDR = 0x0E
FifoRxBaseAddr = 0x00
FifoTxBaseAddr = 0x00
REG_FIFO_RX_BASE_ADDR = 0x0F
REG_FIFO_RX_CURRENT_ADDR = 0x10
REG_IRQ_FLAGS_MASK = 0x11
REG_IRQ_FLAGS = 0x12
REG_RX_NB_BYTES = 0x13
REG_PKT_RSSI_VALUE = 0x1A
REG_PKT_SNR_VALUE = 0x1B
REG_FEI_MSB = 0x1D
REG_FEI_LSB = 0x1E
REG_MODEM_CONFIG = 0x26
REG_PREAMBLE_DETECT = 0x1F
REG_PREAMBLE_MSB = 0x20
REG_PREAMBLE_LSB = 0x21
REG_PAYLOAD_LENGTH = 0x22
REG_FIFO_RX_BYTE_ADDR = 0x25
REG_RSSI_WIDEBAND = 0x2C
REG_DETECTION_OPTIMIZE = 0x31
REG_DETECTION_THRESHOLD = 0x37
REG_SYNC_WORD = 0x39
REG_DIO_MAPPING_1 = 0x40
REG_VERSION = 0x42
# invert IQ
REG_INVERTIQ = 0x33
RFLR_INVERTIQ_RX_MASK = 0xBF
RFLR_INVERTIQ_RX_OFF = 0x00
RFLR_INVERTIQ_RX_ON = 0x40
RFLR_INVERTIQ_TX_MASK = 0xFE
RFLR_INVERTIQ_TX_OFF = 0x01
RFLR_INVERTIQ_TX_ON = 0x00
REG_INVERTIQ2 = 0x3B
RFLR_INVERTIQ2_ON = 0x19
RFLR_INVERTIQ2_OFF = 0x1D
# modes
MODE_LONG_RANGE_MODE = 0x80 # bit 7: 1 => LoRa mode
MODE_SLEEP = 0x00
MODE_STDBY = 0x01
MODE_TX = 0x03
MODE_RX_CONTINUOUS = 0x05
MODE_RX_SINGLE = 0x06
# PA config
PA_BOOST = 0x80
# IRQ masks
IRQ_TX_DONE_MASK = 0x08
IRQ_PAYLOAD_CRC_ERROR_MASK = 0x20
IRQ_RX_DONE_MASK = 0x40
IRQ_RX_TIME_OUT_MASK = 0x80
# Buffer size
MAX_PKT_LENGTH = 255
__DEBUG__ = True
class TTN:
""" TTN Class.
def __init__(self, dev_address, net_key, app_key, country="EU"):
""" Interface for The Things Network.
self.dev_addr = dev_address
self.net_key = net_key
self.app_key = app_key
self.region = country
@property
def device_address(self):
""" Returns the TTN Device Address.
return self.dev_addr
@property
def network_key(self):
""" Returns the TTN Network Key.
return self.net_key
@property
def application_key(self):
""" Returns the TTN Application Key.
return self.app_key
@property
def country(self):
""" Returns the TTN Frequency Country.
return self.region
class SX127x:
_default_parameters = {
'tx_power_level': 2,
'signal_bandwidth': 'SF7BW125',
'spreading_factor': 7,
'coding_rate': 5,
'sync_word': 0x34,
'implicit_header': False,
'preamble_length': 8,
'enable_CRC': False,
'invert_IQ': False,
_data_rates = {
"SF7BW125":(0x74, 0x72, 0x04), "SF7BW250":(0x74, 0x82, 0x04),
"SF8BW125":(0x84, 0x72, 0x04), "SF9BW125":(0x94, 0x72, 0x04),
"SF10BW125":(0xA4, 0x72, 0x04), "SF11BW125":(0xB4, 0x72, 0x0C),
"SF12BW125":(0xC4, 0x72, 0x0C)
def __init__(self,
spi,
pins,
ttn_config,
channel=0, # compatibility with Dragino LG02, set to None otherwise
fport=1,
lora_parameters=_default_parameters):
self._spi = spi
self._pins = pins
self._parameters = lora_parameters
self._lock = False
self._event_rx= asyncio.ThreadSafeFlag()
# setting pins
if "dio_0" in self._pins:
self._pin_rx_done = Pin(self._pins["dio_0"], Pin.IN)
self._irq = Pin(self._pins["dio_0"], Pin.IN)
if "ss" in self._pins:
self._pin_ss = Pin(self._pins["ss"], Pin.OUT)
if "led" in self._pins:
self._led_status = Pin(self._pins["led"], Pin.OUT)
if "reset" in self._pins:
self._reset = Pin(self._pins["reset"], Pin.OUT)
self._reset.value(False)
utime.sleep(1)
self._reset.value(True)
utime.sleep(1)
# check hardware version
init_try = True
re_try = 0
while init_try and re_try < 5:
version = self.read_register(REG_VERSION)
re_try = re_try + 1
if __DEBUG__:
print("SX version: {}".format(version))
if version == 0x12:
init_try = False
utime.sleep_ms(1000)
if version != 0x12:
raise Exception('Invalid version.') # JAMES print("Unsupported version")
# Set frequency registers
self._rfm_msb = None
self._rfm_mid = None
self._rfm_lsb = None
# init framecounter
self.frame_counter = 0
self._fport = fport
# Set datarate registers
self._sf = None
self._bw = None
self._modemcfg = None
# ttn configuration
if "US" in ttn_config.country:
from ttn.ttn_usa import TTN_FREQS
self._frequencies = TTN_FREQS
elif ttn_config.country == "AS":
from ttn.ttn_as import TTN_FREQS
elif ttn_config.country == "AU":
from ttn.ttn_au import TTN_FREQS
elif ttn_config.country == "EU":
from ttn.ttn_eu import TTN_FREQS
raise TypeError("Country Code Incorrect/Unsupported")
# Give the uLoRa object ttn configuration
self._ttn_config = ttn_config
# put in LoRa and sleep mode
self.sleep()
# set channel number
self._channel = channel
self._actual_channel = channel
if self._channel is not None:
self.set_frequency(self._channel)
# set data rate and bandwidth
self.set_bandwidth(self._parameters["signal_bandwidth"])
# set LNA boost
self.write_register(REG_LNA, self.read_register(REG_LNA) | 0x03)
# set auto AGC
self.write_register(REG_MODEM_CONFIG, 0x04)
self.implicit_header_mode(self._parameters['implicit_header'])
self.set_tx_power(self._parameters['tx_power_level'])
self.set_coding_rate(self._parameters['coding_rate'])
self.set_sync_word(self._parameters['sync_word'])
self.enable_CRC(self._parameters['enable_CRC'])
#self.invert_IQ(self._parameters["invert_IQ"])
self.set_preamble_length(self._parameters['preamble_length'])
self.set_spreading_factor(self._parameters['spreading_factor'])
# set LowDataRateOptimize flag if symbol time > 16ms (default disable on reset)
# self.write_register(REG_MODEM_CONFIG, self.read_register(REG_MODEM_CONFIG) & 0xF7) # default disable on reset
#bw_parameter = self._parameters["signal_bandwidth"]
#sf_parameter = self._parameters["spreading_factor"]
#if 1000 / (bw_parameter / 2**sf_parameter) > 16:
# REG_MODEM_CONFIG,
# self.read_register(REG_MODEM_CONFIG) | 0x08
# set base addresses
self.write_register(REG_FIFO_TX_BASE_ADDR, FifoTxBaseAddr)
self.write_register(REG_FIFO_RX_BASE_ADDR, FifoRxBaseAddr)
self.standby()
def begin_packet(self, implicit_header_mode = False):
self.standby()
self.implicit_header_mode(implicit_header_mode)
#self.write_register(REG_DIO_MAPPING_1, 0x40)
# Check for multi-channel configuration
if self._channel is None:
self._actual_channel = urandom.getrandbits(3)
self.set_frequency(self._actual_channel)
# reset FIFO address and paload length
self.write_register(REG_FIFO_ADDR_PTR, FifoTxBaseAddr)
self.write_register(REG_PAYLOAD_LENGTH, 0)
def end_packet(self, timeout=5):
# put in TX mode
self.write_register(REG_OP_MODE, MODE_LONG_RANGE_MODE | MODE_TX)
start = utime.time()
timed_out = False
# wait for TX done, standby automatically on TX_DONE
#self.read_register(REG_IRQ_FLAGS) & IRQ_TX_DONE_MASK == 0 and \
irq_value = self.read_register(REG_IRQ_FLAGS)
while not timed_out and \
irq_value & IRQ_TX_DONE_MASK == 0:
if utime.time() - start >= timeout:
timed_out = True
if timed_out:
raise RuntimeError("Timeout during packet send")
# clear IRQ's
self.write_register(REG_IRQ_FLAGS, IRQ_TX_DONE_MASK)
self.collect_garbage()
def write(self, buffer, buffer_length):
# update length
self.write_register(REG_PAYLOAD_LENGTH, buffer_length)
# write data
for i in range(buffer_length):
self.write_register(REG_FIFO, buffer[i])
def set_lock(self, lock = False):
self._lock = lock
def send_data(self, data, data_length, frame_counter, timeout=5):
# Data packet
enc_data = bytearray(data_length)
lora_pkt = bytearray(64)
# Copy bytearray into bytearray for encryption
enc_data[0:data_length] = data[0:data_length]
# Encrypt data (enc_data is overwritten in this function)
self.frame_counter = frame_counter
aes = AES(
self._ttn_config.device_address,
self._ttn_config.app_key,
self._ttn_config.network_key,
self.frame_counter
enc_data = aes.encrypt(enc_data)
# Construct MAC Layer packet (PHYPayload)
# MHDR (MAC Header) - 1 byte
lora_pkt[0] = REG_DIO_MAPPING_1 # MType: unconfirmed data up, RFU / Major zeroed
# MACPayload
# FHDR (Frame Header): DevAddr (4 bytes) - short device address
lora_pkt[1] = self._ttn_config.device_address[3]
lora_pkt[2] = self._ttn_config.device_address[2]
lora_pkt[3] = self._ttn_config.device_address[1]
lora_pkt[4] = self._ttn_config.device_address[0]
# FHDR (Frame Header): FCtrl (1 byte) - frame control
lora_pkt[5] = 0x00
# FHDR (Frame Header): FCnt (2 bytes) - frame counter
lora_pkt[6] = self.frame_counter & 0x00FF
lora_pkt[7] = (self.frame_counter >> 8) & 0x00FF
# FPort - port field
lora_pkt[8] = self._fport
# Set length of LoRa packet
lora_pkt_len = 9
if __DEBUG__:
print("PHYPayload", ubinascii.hexlify(lora_pkt))
# load encrypted data into lora_pkt
lora_pkt[lora_pkt_len : lora_pkt_len + data_length] = enc_data[0:data_length]
if __DEBUG__:
print("PHYPayload with FRMPayload", ubinascii.hexlify(lora_pkt))
# Recalculate packet length
lora_pkt_len += data_length
# Calculate Message Integrity Code (MIC)
# MIC is calculated over: MHDR | FHDR | FPort | FRMPayload
mic = bytearray(4)
mic = aes.calculate_mic(lora_pkt, lora_pkt_len, mic)
# Load MIC in package
lora_pkt[lora_pkt_len : lora_pkt_len + 4] = mic[0:4]
# Recalculate packet length (add MIC length)
lora_pkt_len += 4
if __DEBUG__:
print("PHYPayload with FRMPayload + MIC", ubinascii.hexlify(lora_pkt))
self.send_packet(lora_pkt, lora_pkt_len, timeout)
def send_packet(self, lora_packet, packet_length, timeout):
""" Sends a LoRa packet using the SX1276 module.
self.set_lock(True) # wait until RX_Done, lock and begin writing.
self.begin_packet()
# Fill the FIFO buffer with the LoRa payload
self.write(lora_packet, packet_length)
# Send the package
self.end_packet(timeout)
self.set_lock(False) # unlock when done writing
self.blink_led()
def get_irq_flags(self):
irq_flags = self.read_register(REG_IRQ_FLAGS)
if __DEBUG__:
irq_dict = dict(
rx_timeout = irq_flags >> 7 & 0x01,
rx_done = irq_flags >> 6 & 0x01,
crc_error = irq_flags >> 5 & 0x01,
valid_header = irq_flags >> 4 & 0x01,
tx_done = irq_flags >> 3 & 0x01,
cad_done = irq_flags >> 2 & 0x01,
fhss_change_ch = irq_flags >> 1 & 0x01,
cad_detected = irq_flags >> 0 & 0x01,
print(irq_dict)
self.write_register(REG_IRQ_FLAGS, irq_flags)
return irq_flags
def packet_rssi(self):
# TODO
rssi = self.read_register(REG_PKT_RSSI_VALUE)
return rssi
#return (rssi - (164 if self._frequency < 868E6 else 157))
def packet_snr(self):
snr = self.read_register(REG_PKT_SNR_VALUE)
return snr * 0.25
def standby(self):
self.write_register(REG_OP_MODE, MODE_LONG_RANGE_MODE | MODE_STDBY)
utime.sleep_ms(10)
def sleep(self):
self.write_register(REG_OP_MODE, MODE_LONG_RANGE_MODE | MODE_SLEEP)
utime.sleep_ms(10)
def set_tx_power(self, level, outputPin=PA_OUTPUT_PA_BOOST_PIN):
self._tx_power_level = level
if (outputPin == PA_OUTPUT_RFO_PIN):
# RFO
level = min(max(level, 0), 14)
self.write_register(REG_PA_CONFIG, 0x70 | level)
# PA BOOST
level = min(max(level, 2), 17)
self.write_register(REG_PA_CONFIG, PA_BOOST | (level - 2))
def set_frequency(self, channel):
self.write_register(REG_FRF_MSB, self._frequencies[channel][0])
self.write_register(REG_FRF_MID, self._frequencies[channel][1])
self.write_register(REG_FRF_LSB, self._frequencies[channel][2])
def set_coding_rate(self, denominator):
denominator = min(max(denominator, 5), 8)
cr = denominator - 4
REG_FEI_MSB,
(self.read_register(REG_FEI_MSB) & 0xf1) | (cr << 1)
def set_preamble_length(self, length):
self.write_register(REG_PREAMBLE_MSB, (length >> 8) & 0xff)
self.write_register(REG_PREAMBLE_LSB, (length >> 0) & 0xff)
def set_spreading_factor(self, sf):
sf = min(max(sf, 6), 12)
self.write_register(REG_DETECTION_OPTIMIZE, 0xc5 if sf == 6 else 0xc3)
self.write_register(REG_DETECTION_THRESHOLD, 0x0c if sf == 6 else 0x0a)
self.write_register(REG_FEI_LSB, (self.read_register(REG_FEI_LSB) & 0x0f) | ((sf << 4) & 0xf0))
def set_bandwidth(self, datarate):
sf, bw, modemcfg = self._data_rates[datarate]
self.write_register(REG_FEI_LSB, sf)
self.write_register(REG_FEI_MSB, bw)
self.write_register(REG_MODEM_CONFIG, modemcfg)
except KeyError:
raise KeyError("Invalid or Unsupported Datarate.")
def enable_CRC(self, enable_CRC = False):
modem_config_2 = self.read_register(REG_FEI_LSB)
config = modem_config_2 | 0x04 if enable_CRC else modem_config_2 & 0xfb
self.write_register(REG_FEI_LSB, config)
def invert_IQ(self, invert_IQ):
self._parameters["invertIQ"] = invert_IQ
if invert_IQ:
REG_INVERTIQ,
self.read_register(REG_INVERTIQ)
& RFLR_INVERTIQ_TX_MASK
& RFLR_INVERTIQ_RX_MASK
| RFLR_INVERTIQ_RX_ON
| RFLR_INVERTIQ_TX_ON
self.write_register(REG_INVERTIQ2, RFLR_INVERTIQ2_ON)
REG_INVERTIQ,
self.write_register(REG_INVERTIQ2, RFLR_INVERTIQ2_OFF)
def set_sync_word(self, sw):
self.write_register(REG_SYNC_WORD, sw)
def dump_registers(self):
for i in range(128):
print("0x{:02X}: {:02X}".format(i, self.read_register(i)), end="")
if (i + 1) % 4 == 0:
print()
print(" | ", end="")
def implicit_header_mode(self, implicit_header_mode = False):
self._implicit_header_mode = implicit_header_mode
modem_config_1 = self.read_register(REG_FEI_MSB)
config = (modem_config_1 | 0x01
if implicit_header_mode else modem_config_1 & 0xfe)
self.write_register(REG_FEI_MSB, config)
def receive(self, size = 0):
self.implicit_header_mode(size > 0)
if size > 0:
self.write_register(REG_PAYLOAD_LENGTH, size & 0xff)
# The last packet always starts at FIFO_RX_CURRENT_ADDR
# no need to reset FIFO_ADDR_PTR
REG_OP_MODE, MODE_LONG_RANGE_MODE | MODE_RX_CONTINUOUS
async def on_receive(self, callback):
self._on_receive = callback
if self._pin_rx_done:
if callback:
print("callback attached")
self.write_register(REG_DIO_MAPPING_1, 0x00)
self._pin_rx_done.irq(handler=self._pin_rx_done_handler, trigger=Pin.IRQ_RISING)
await self.handle_on_receive()
self._pin_rx_done.irq(handler=None, trigger=0)
def _pin_rx_done_handler(self, pin):
self._event_rx.set()
############# changes are from here ################
async def handle_on_receive(self):
print('waiting rx')
await self._event_rx.wait()
print('irq triggered')
rx_income_ms = utime.ticks_ms()
self.set_lock(True) # lock until TX_Done
while utime.ticks_diff(utime.ticks_ms(), rx_income_ms) < 3000: # Set timeout=3000ms
irq_flags = self.get_irq_flags()
if irq_flags == IRQ_RX_DONE_MASK: # RX_DONE only, irq_flags should be 0x40
# automatically standby when RX_DONE
if self._on_receive_cb:
print('msg coming in')
payload = self.read_payload()
self._on_receive_cb(payload)
break
await asyncio.sleep(0)
# elif self.read_register(REG_OP_MODE) != (MODE_LONG_RANGE_MODE | MODE_RX_SINGLE):
# print('no msg received')
# # no packet received.
# # reset FIFO address / # enter single RX mode
# self.write_register(REG_FIFO_ADDR_PTR, FifoRxBaseAddr)
# self.write_register(REG_OP_MODE, MODE_LONG_RANGE_MODE | MODE_RX_SINGLE)
self.set_lock(False) # unlock in any case.
############# changes are up to here ################
def received_packet(self, size = 0):
if size > 0:
#if (irq_flags & IRQ_RX_DONE_MASK) and \
# (irq_flags & IRQ_RX_TIME_OUT_MASK == 0) and \
# (irq_flags & IRQ_PAYLOAD_CRC_ERROR_MASK == 0):
if (irq_flags == IRQ_RX_DONE_MASK):
return True
REG_OP_MODE,
def read_payload(self):
# set FIFO address to current RX address
# fifo_rx_current_addr = self.read_register(REG_FIFO_RX_CURRENT_ADDR)
REG_FIFO_ADDR_PTR,
# read packet length
if self._implicit_header_mode:
packet_length = self.read_register(REG_PAYLOAD_LENGTH)
packet_length = self.read_register(REG_RX_NB_BYTES)
payload = bytearray()
for i in range(packet_length):
payload.append(self.read_register(REG_FIFO))
return bytes(payload)
def read_register(self, address, byteorder = 'big', signed = False):
response = self.transfer(address & 0x7f)
return int.from_bytes(response, byteorder)
def write_register(self, address, value):
self.transfer(address | 0x80, value)
def transfer(self, address, value = 0x00):
response = bytearray(1)
self._pin_ss.value(0)
self._spi.write(bytes([address]))
self._spi.write_readinto(bytes([value]), response)
self._pin_ss.value(1)
return response
def blink_led(self, times = 1, on_seconds = 0.1, off_seconds = 0.1):
for i in range(times):
if self._led_status:
self._led_status.value(True)
utime.sleep(on_seconds)
self._led_status.value(False)
utime.sleep(off_seconds)
def collect_garbage(self):
gc.collect()
#if __DEBUG__:
# print('[Memory - free: {} allocated: {}]'.format(gc.mem_free(), gc.mem_alloc()))
That part of the program looks correct to me, including your use of ThreadSafeFlag.
This looks like a really useful library: you might like to publish and document it for others to use.
