Page 1 of 2
Install aioble with upip?
Posted: Wed Oct 20, 2021 9:22 am
by esp32bob
Should I be able to add the 'aioble' library to esp32 with upip?
If not, what is the recommended method?
I am using rshell already
Re: Install aioble with upip?
Posted: Wed Oct 20, 2021 6:15 pm
by davef
Posted: Wed Oct 20, 2021 9:21 pm
by esp32bob
Thanks for the reply, but that thread already assumes the aioble libraries are installed.
I am asking how to install them
--P
Posted: Thu Oct 21, 2021 12:08 am
by davef
Sorry, I thought you just copied all those files at :
https://github.com/micropython/micropyt ... ble/aioble
to flash on the ESP32 and away you go.
Posted: Thu Oct 21, 2021 1:26 am
by davef
Or are you asking how to use rshell to copy any files to your device?
Posted: Thu Oct 21, 2021 6:49 am
by esp32bob
davef wrote: ↑Thu Oct 21, 2021 1:26 am
Yes, I am asking how to install the aioble library onto the device. You can tell I am not a python developer, I just use python to get networking things working. Copy a file called "aioble.py" and then "import aioble" was what I was hoping for
I can not use upip, and just copying the files within rshell doesn't work for me.
eg;
cp /opt/micropython-lib/micropython/bluetooth/aioble/aioble/* /pyboard
Posted: Thu Oct 21, 2021 7:01 am
by davef
I wasn't going to assume anything
Are you running rshell in Linux?
What image do you have on your device?
What board are you using?
If you cd to /pyboard/ and do a ls do you see files on the board?
Do you get an error msg when you do:
Can you copy any files to your board?
Posted: Thu Oct 21, 2021 7:04 am
by davef
When the files are copied to /pyboard/
then you should be able to do:
cd /pyboard
repl
Ctrl-D
import aioble
Then we can deal with the errors that arise from that.
Posted: Thu Oct 21, 2021 7:41 am
by esp32bob
Thanks for your help.
All of the files from that folder are in /pyboard
/pyboard> ls
lib/ ble_temperature.py bt_test.py core.py main.py server.py
__init__.py boot.py central.py device.py peripheral.py test2.py
ble_advertising.py bt_irq.py client.py l2cap.py security.py wifi.py
/pyboard> repl
Entering REPL. Use Control-X to exit.
MicroPython v1.17 on 2021-09-02; ESP32 module with ESP32
>>> import aioble
ImportError: no module named 'aioble'
Posted: Thu Oct 21, 2021 8:10 am
by davef
Right. I had a look at the file called manifest.py maybe you have to do something with that. I don't know what the term <freeze> means. Had a look at python keyword freeze and it looks like it was not implemented.
Good luck!
