Install aioble with upip?
esp32bob
Re: Install aioble with upip?
Post by esp32bob » Thu Oct 21, 2021 8:12 am
If I copy
__init__.py
to
aioble.py
then I get this error:
>>> import aioble.py
  File "aioble.py", line 6, in <module>
ImportError: can't perform relative import
esp32bob
Post by esp32bob » Thu Oct 21, 2021 8:28 am
davef wrote:
Thu Oct 21, 2021 7:04 am
When the files are copied to /pyboard/
then you should be able to do:
cd /pyboard
repl
Ctrl-D
import aioble
Then we can deal with the errors that arise from that.
Finally got it all working. Thanks for your interest and help. I *was sure* I have tried this before, but here is what worked this time.
All in rshell.
/pyboard> mkdir aioble
cp /opt/micropython-lib/micropython/bluetooth/aioble/aioble/* ./aioble
/pyboard> repl
Entering REPL. Use Control-X to exit.
MicroPython v1.17 on 2021-09-02; ESP32 module with ESP32
>>> import aioble
Can't explain why that didn't work before.
davef
Post by davef » Thu Oct 21, 2021 8:34 am
Great. For my edification can you explain:
/pyboard> repl
I would have expected the command to be:
cp /opt/micropython-lib/micropython/bluetooth/aioble/aioble/* /pyboard/aioble/> repl
The specific part .... ./aioble/pyboard
Post by dhylands » Thu Oct 21, 2021 6:03 pm
I think that the first command assumed that the current directory was /pyboard.
Using /pyboard/aioble eliminates the current directory from the equation (i.e. it will work regardless of the current directory is).
And to be clear, I'm saying that this:
cd /pyboard
is equivalent to
The first example that shows /pyboard> repl on the second line is showing the prompt (/pyboard>) followed by a command (repl).
The second example has an extraneous /> repl at the end of the line which shouldn't be there.
davef
Post by davef » Thu Oct 21, 2021 6:35 pm
Dave,
Thank you for the clear explanation. When I saw ./aioble I thought it was running aioble like one does with a Bash or Python script from the command line.
Post by dhylands » Thu Oct 21, 2021 10:12 pm
./aioble is just a relative path. If it’s the first thing on the command line then you would be executing a program. If it’s not the first thing then is just an argument being passed to a program and could refer to a file or a directory.
davef
Post by davef » Fri Oct 22, 2021 4:17 am
Thanks.
esp32bob
Post by esp32bob » Sun Oct 24, 2021 5:58 am
cd /pyboard
is equivalent to
Sorry for the delay in replying. This is exactly what I was doing. I was already in
/pyboard
and so used
./aioble
rather than the more explict
/pyboard/aioble
Thank you both for the help and information
PieyeGmbH
Post by PieyeGmbH » Tue Jun 27, 2023 10:34 pm
That might help:
https://github.com/micropython/micropyt ... ree/master
for me, the following did the trick:
import mip
mip.install("aioble")
import aioble
