Can't edit the Wiki
Can't edit the Wiki
Post by pythoncoder » Sun Oct 31, 2021 11:28 am
I think this is a consequence of GitHub moving to access tokens. The last time I edited the Wiki was in August, but now I can't authenticate with GitHub; I'm guessing that GitHub may have disabled password access since then. On GitHub I used an access token since they first became available without problems.
Any ideas how to fix this, or failing that how to use OAuth?
Re: Can't edit the Wiki
Post by dhylands » Sun Oct 31, 2021 5:50 pm
I use a regular login on github, but I use SSH access for command line acess (i.e. no login required).
This requires you to setup a public/private SSH key and I have a login script which uses ssh-agent which does the SSH key management.
https://github.com/dhylands/dotfiles/bl ... h-agent.sh
You need to add the SSH public key to github: https://github.com/settings/keys
Post by dhylands » Sun Oct 31, 2021 5:56 pm
More info here: https://docs.github.com/en/authenticati ... b-with-ssh
I also discovered a way t deal with multiple github accounts. I have a work account and a personal account. github only allows you to be logged into one account at a time.
In the chrome browser, you can create multiple profiles and each profile can be logged into github using a different account, so you don't need to keep logging out and logging back in. I give the different profiles different background colors so that I can easily tell them apart.
Post by pythoncoder » Sun Oct 31, 2021 6:07 pm
Sorry if I'm being dumb here, but are you saying that if I set up SSH access to GitHub I'll be able to edit the MicroPython wiki? I'm struggling to see why this would work.
Post by dhylands » Sun Oct 31, 2021 6:24 pm
I guess it depends on which micropython wiki you're referring to, and I was also slightly confused by what was being asked when I responded.
There is a github micropython wiki which can be found here: https://github.com/micropython/micropython/wiki and hmm. I know I used to be able to edit that, but it appears that I can't any more. So @dpgeorge must have changed the permissions.
There is also a wiki at https://wiki.micropython.org/Home and there is an Edit button available there. However, the edit button there wants github/googleauth and neither of those appear to actually work either.
So it looks like @dpgeaorge need to update something before either wiki is editable again.
Post by pythoncoder » Mon Nov 01, 2021 11:07 am
It was the second I was referring to - sorry for the lack of clarity. Thanks for confirming the problem. I'll raise an issue.
mattyt
Post by mattyt » Mon Nov 01, 2021 10:53 pm
So there are actually, currently, three MicroPython wiki's (that I'm aware of)!
I believe the goal is to end up using Mediawiki at the wiki.micropython.org address. I think the idea was to migrate useful information from the first two to the third, but I'll try and get Damien or Jim to comment definitively.
(I've been using the third, Mediawiki system to edit the Standard Library Coverage).
Damien
Site Admin
Post by Damien » Thu Nov 04, 2021 4:46 am
I've updated the wiki base URL to now go straight to the new MediaWiki installation: https://wiki.micropython.org
The previous Gollum-based wiki is now found by inserting "gollum/" in the URL, eg https://wiki.micropython.org/gollum/Home
I've also added a link from the new wiki to the old gollum one to make it easy to find.
Post by pythoncoder » Thu Nov 04, 2021 11:41 am
I can log into the new one but still can't edit the old one: the links on the authorisation screen are 404's.
Is there a plan to migrate content from old to new?
