Hello, I'm working on a project (with an ESP32-WROOM-32 board) that needs to entablish a connection and listen to a websocket, more specifically to get realtime data from the Binance websocket (not much data, only the latest prices of two or three pairs).
I found several examples and tutorials about how to code a websocket server, but almost none examples or code on how to connect as a client (in this case to the Binance websocket) and wait/listen for data from it.
Came across to this library: https://github.com/jczic/MicroWebSrv2
which looks great and have examples to code a webserver, but due to my lack of experience in websockets I cannot realize (or understand) how to connect to a websocket (as a client) with this library...or another one.
The websocket I want to connect to is: wss://stream.binance.com:9443
API Docs: https://binance-docs.github.io/apidocs/ ... et-streams
Can someone provide some example or give me some clue on how to do what I'm trying to do?
Thanks in advance.
Websocket client question.
Re: Websocket client question.
What's wrong with google ?
Asking for "websocket client" gives me e.g. in the 5th link https://github.com/websocket-client/websocket-client (not for microypython, but enough code to steal from).
A few hours of debugging might save you from minutes of reading the documentation!
Thanks karfas for your reply.
As you said, it's not for Micropython (I couldnt be able to install it). I searched A LOT in Google, found some libraries (like the one I posted in my original question) but none of them show how to use them as client. So I though that it could be something simple to do with the available Micropython websocket libraries...I'm starting to think that I was wrong.
Sorry if it is a very simple thing, I just can't find anything related.
Thank you.
Thank you.
