micropython_eeprom Library - OSError 19 mounting external FLASH
Posted: Fri Dec 10, 2021 7:39 pm
by ExDes
Hello all,
I am attempting to mount a set of three S25FL128L FLASH devices on a NUCLEO-F767ZI board using the library micropython_eeprom. All seems to go well until I attempt to mount the devices, and then receive an error code 19, "No such device". Code as follows:
>>> import os
>>> from machine import SPI, Pin
>>> from flash_spi import FLASH
>>> cspins = (Pin(Pin.cpu.A4, Pin.OUT, value=1), Pin(Pin.cpu.A15, Pin.OUT, value=1), Pin(Pin.cpu.C7, Pin.OUT, value=1))
>>> flash = FLASH(SPI(3, baudrate=20_000_000), cspins)
3 chips detected. Total flash size 48MiB.
>>> os.VfsFat.mkfs(flash)
>>> os.mount(flash,'/fl_ext')
OSError: [Errno 19] ENODEV
I run into the same problem if specifying only one single device. If I access a single byte in each device, all seems to go well:
>>> flash[2000] = 42
>>> print(flash[2000])
42
>>> flash[20000000] = 21
>>> print(flash[20000000])
21
>>> flash[40000000] = 64
>>> print(flash[40000000])
64
I have spent a great deal of time on this, and any help would be much appreciated.
Re: micropython_eeprom Library - OSError 19 mounting external FLASH
Posted: Sat Dec 11, 2021 9:42 am
The S25FL128L is one of the devices I have tested thoroughly on Pyboard and ESP32 hosts. I don't have a NUCLEO-F767ZI board so I can't replicate your results.
Have you run the test script flash/flash_test.py? I suggest you do. You'll need to adapt the very start of the code to match your hardware. Run test() and, if this is OK, full_test(count=10). If that passes your hardware is OK. Then run fstest(format=True) to create the filesystem. If that succeeds the filesystem will be mounted on /fl_ext.
If fstest fails I suspect a firmware problem on the Nucleo.
