Raspberry Pi Pico, MicroPython disappears from windows when UF2 File is added
megb123
Post by megb123 » Mon Dec 13, 2021 5:29 pm
We have just started using MicroPython (using CircuitPython previously) and have been unsuccessful when downloading the UF2 file and moving it onto the RPI-RP2 D: drive that appears when plugging in the pico.
This is what we did:
1. Plugged in Pico (USB cable to PC) while holding BOOTSEL
2. Windows recognised as drive D:
3. 2 files visible INDEX.HTM & INFO_UF2.txt
UF2 Bootloader v2.0
Model: Raspberry Pi RP2
Board-ID: RPI-RP2
4. Downloaded rp2-pico-20210618-v1.16.uf2 from https://micropython.org/download/rp2-pico/
5. Dragged and dropped onto O:
6. Pico then disappears from windows
However the coding on Thonny still works - able to turn board LED on / off for example.
Is it normal that we cannot see it in the file explorer?
We have tried hundreds of times, tried nuking the pico, tried changing computer, going from Microsoft to apple.
Is the raspberry pi pico perhaps broken?
Can we still continue coding even though we cannot see it in the files?
How can we drag and drop any libraries into the MicroPython pico if we cannot see it?
Please reply if you have any tips.
Thank you.
scruss
Re: Raspberry Pi Pico, MicroPython disappears from windows when UF2 File is added
Post by scruss » Mon Dec 13, 2021 6:58 pm
Yes. Unlike CircuitPython, MicroPython doesn't create a USB drive.
megb123
Post by megb123 » Mon Dec 13, 2021 7:38 pm
Okay, how would we be able to add libraries or do we not need to? For example for HX711?
Thank you for your help,
Post by Roberthh » Mon Dec 13, 2021 7:48 pm
You can use rshell, mpremote, Thonny, or other IDEs for that task.
megb123
Post by megb123 » Mon Dec 13, 2021 7:53 pm
Currently using Thonny, would we need import libraries onto the device, if so how?
scruss
Post by scruss » Tue Dec 14, 2021 3:52 am
Use Thonny's Files pane (View -> Files):
thonny: files pane
megb123
Post by megb123 » Wed Dec 15, 2021 2:50 pm
Thank you very much, all up and working now!
