I'm very new to python so this is probably a stupied question but here we go.
So, i'm having a small project where I'm trying to use a Rest API with the pico raspberry with the small ESP8266 card.
And the wificonnections works very well with the UART module. However when I come to the urequests part i getting some issues.
I'm using the Thonny app at windows to control the pico and micropython, I installed ureqquests from the nice "Managed packages for Raspberry Pi Pico" menu. I tried import urequests and the shell told me to install usocket and socket so from the same menu I choosed the "micropython-socket" package and "micropython-cpython-usocket" package. And I then tried from the shell:
urequests.request(method="GET",url="http://www.baidu.com/")
File "/lib/urequests.py", line 55, in request
AttributeError: 'module' object has no attribute 'getaddrinfo'
import micropython
from socket import *
from usocket import *
import usocket as _socket
SOCK_SEQPACKET = 5
_GLOBAL_DEFAULT_TIMEOUT = 30
IPPROTO_IP = 0
IP_ADD_MEMBERSHIP = 35
IP_DROP_MEMBERSHIP = 36
INADDR_ANY = 0
error = OSError
def _resolve_addr(addr):
if isinstance(addr, (bytes, bytearray)):
return addr
family = _socket.AF_INET
if len(addr) != 2:
family = _socket.AF_INET6
if addr[0] == "":
a = "0.0.0.0" if family == _socket.AF_INET else "::"
a = addr[0]
a = getaddrinfo(a, addr[1], family)
return a[0][4]
def inet_aton(addr):
return inet_pton(AF_INET, addr)
def create_connection(addr, timeout=None, source_address=None):
s = socket()
#print("Address:", addr)
ais = getaddrinfo(addr[0], addr[1])
#print("Address infos:", ais)
for ai in ais:
s.connect(ai[4])
return s
except:
pass
class socket(_socket.socket):
def accept(self):
s, addr = super().accept()
addr = _socket.sockaddr(addr)
return (s, (_socket.inet_ntop(addr[0], addr[1]), addr[2]))
def bind(self, addr):
return super().bind(_resolve_addr(addr))
def connect(self, addr):
return super().connect(_resolve_addr(addr))
def sendall(self, *args):
return self.send(*args)
def sendto(self, data, addr):
return super().sendto(data, _resolve_addr(addr))
Can I solve this some how?
