Altitude with BMP180
Euzikial
Post by Euzikial » Wed Mar 09, 2022 8:05 am
So it turns out that BMP180.py driver calculates altitude wrongly as it is showing me that I live on a mountain (870+ meters) while im almost sitting at the beach
p = -7990.0*math.log(self.pressure/self.baseline)
i have changed it to
p = (44331.5 - 4946.62 *self.pressure**(0.190263)
using the part of the code from
https://pvlib-python.readthedocs.io/.../atmosphere.html
and it came back with the same results - 870+ meters while google maps are saying im at 7+ meters.
Is it wrong if I divide by 10 the result of one of the formulas? f/e
p = (44331.5 - 4946.62 *self.pressure**(0.190263))/10
Re: Altitude with BMP180
Post by Roberthh » Wed Mar 09, 2022 8:37 am
I do not know which driver you use, but in my driver I use:
            p = 44330 * (1.0 - math.pow(self.pressure /
                                        self._baseline, 0.1903))
where _baseline is the actual pressure at sea level, which will change all the time. You get that pressure typically from the weather reports, which tell you this "normalized" value. You cannot calculate the height just using the pressure without reference to the actual sea level pressure, which is the zero level of your scale.
Euzikial
Post by Euzikial » Thu Mar 10, 2022 2:53 am
Thank you for your input. I will look into it. And yes I do update QNH (local baro pressure at sea level) every two hours.
I will update the formula and see what happens
Euzikial
Post by Euzikial » Thu Mar 10, 2022 5:17 am
What is your source of your code?
Post by Roberthh » Thu Mar 10, 2022 6:59 am
My driver is here: https://github.com/robert-hh/BMP085_BMP180
As told, is was derived from a different implementation.
