RP2: Problem copying files using rshell to Pico over USB
Posted: Thu Mar 17, 2022 12:51 pm
I have been having problems copying some files from the host (a Raspberry Pi 4B) to a Pico (RP2) using USB. The Pico has MicroPython v1.18 and I am using rshell v0.0.31 to do the copy.
If I try and copy any file that has a file size which is a multiple of 32 bytes but is *not* a multiple of 128 bytes then the file transfer results in the Pico hard hanging at the end of the transfer. The file does not end up being transferred, only a zero length file is created on the Pico. For example, files of size 32, 64, 96, 160, 192, 224, 288, etc bytes will fail to transfer. Files of other sizes that are not in the sequence transfer fine.
The rshell command I am using is:
The rsync command also fails to work with files of the problematic size.
I have done some debugging in rshell and the problem appears to be in the function recv_file_from_host which fails when it hits the line:
when read_size is one of the problematic values. As I understand it this indicated a bug in the underlying MicroPython implementation of the buffered IO stream being used by sys.stdin.
Note I have replicated the problem with two different Pico boards and MicroPython v1.17 and the latest nightly v1.18-218.
Any insight would be appreciated.
Regards - Mark
cp filename.ext /pyboard
bytes_read = sys.stdin.readinto(read_buf, read_size)
Regards - Mark
