micropython-mpu9x50 on custom 1.18. firmware
mekanixms
Post by mekanixms » Tue Mar 29, 2022 8:10 am
I need to have some libraries frozen into the firmware (ESP32) for a project I work on. Using the standard compiling approach, I build the latest 1.18 firmware with IDF 4.4
Looks like a build/configuration problem because now I get the bellow exception when trying to load the MPU6050 library (https://github.com/micropython-IMU/micropython-mpu9x50)
Must say that I tested on the standard firmware, downloaded from micropython website, and works well.
How should I compile the firmware so I get rid of this issue?
>>> from machine import Pin,I2C
>>> from imu import MPU6050
>>> i2c = I2C(0)
>>> imu = MPU6050(i2c)
Guru Meditation Error: Core  1 panic'ed (StoreProhibited). Exception was unhandled.
Core  1 register dump:
PC      : 0x4008c8b4  PS      : 0x00060031  A0      : 0x8008ca49  A1      : 0x3ffbeed0
A2      : 0x3ffd9a7c  A3      : 0x00000000  A4      : 0x00000000  A5      : 0x00000800
A6      : 0x3ffbd680  A7      : 0x80000002  A8      : 0x3ffd8408  A9      : 0x00000901
A10     : 0x00000003  A11     : 0x00060023  A12     : 0x00000001  A13     : 0x3ffd840c
A14     : 0x00000000  A15     : 0x3ff53000  SAR     : 0x0000001d  EXCCAUSE: 0x0000001d
EXCVADDR: 0x00000008  LBEG    : 0x00000000  LEND    : 0x00000000  LCOUNT  : 0x00000000
Backtrace:0x4008c8b1:0x3ffbeed00x4008ca46:0x3ffbef10 0x40082c71:0x3ffbef40 0x401d9d17:0x3ffca6d0 0x400d2d87:0x3ffca6f0 0x400963dc:0x3ffca710
Re: micropython-mpu9x50 on custom 1.18. firmware
Post by pythoncoder » Tue Mar 29, 2022 9:43 am
Does the import fail only when the module is frozen? If the module imports OK when not frozen, I'd try cross compiling it. Delete the .py file from the target and replace with the .mpy. If that fails you may need to rebuild the cross compiler. (Frozen byte code is cross-compiled at build time).
mekanixms
Post by mekanixms » Tue Mar 29, 2022 1:13 pm
The module imports ok. In this specific case I have it compiled to mpy and included in ports/esp32/modules.
Anyway, it works well both compiled or simple .py when is not frozen, on any firmware
After further testing (In repl, as you can see in the code posted) it seems the crash appears when creating an instance for the mpu, MPU6050(I2C(0)) and only when the mpu9x50 libs are frozen
All the other modules I have, working with ADC or digital inputs, i2c displays,... work well frozen in the firmware.
I suspect is something inside MPU9x50 library causing the crash
Post by pythoncoder » Wed Mar 30, 2022 12:40 pm
If you can import it and use it as an mpy file I'm baffled as to why it fails when frozen. The module is standard Python throughout.
Totally clutching at straws here, but it might be interesting to see if soft I2C makes any difference.
mekanixms
Post by mekanixms » Thu Mar 31, 2022 7:24 am
After further testing I notice that:
  1. with the standard 1.17 firmware, I can create an instance of MPU6050
MicroPython v1.17 on 2021-09-02; ESP32 module with ESP32
>>> from machine import I2C
>>> imu=MPU6050(I2C(0))
  • with the standard 1.18 firmware, I can create an instance of MPU6050
MicroPython v1.18 on 2022-01-17; ESP32 module with ESP32
>>> imu=MPU6050(I2C(0))
  • with the compiled 1.18 firmware, I get the error when instancing MPU6050
this compilation did not had the modules frozen in the firmware
MicroPython v1.18-257-g35dbde163 on 2022-03-31; ESP32 module with ESP32
>>> imu=MPU6050(I2C(0))
Given above I think is something related to the way I compile firmware. Even if I folow the standard procedure it may be that the configuration/optimization is different in the github nightly from the micropython standard releases.
Any suggestion what configuration/optimizations to use for compilation?
mekanixms
Post by mekanixms » Thu Mar 31, 2022 8:02 am
Micropython 1.18 standard, no issues both on I2C and SoftI2c
imu=MPU6050(I2C(0))
imu=MPU6050(SoftI2C(scl=Pin(18),sda=Pin(19)))
Surprise, current 1.8, reboots on I2C but not on SoftI2c!
>>> from machine import SoftI2C,Pin
>>> imu=MPU6050(I2C(0))
Many thanks @pythoncoder for pointing this out to me!
Looks like I2C is indeed gone in the next stable and SoftI2C is the way to go
Post by pythoncoder » Thu Mar 31, 2022 8:18 am
Out of interest could you please try hard I2C, but this time specifying the pins to the constructor:
imu=MPU6050(I2C(0, scl=Pin(18),sda=Pin(19)))
mekanixms
Post by mekanixms » Thu Mar 31, 2022 8:31 am
Of Course, find below please
mekanixms
Post by mekanixms » Thu Mar 31, 2022 8:32 am
just FYI, above tested with the modules frozen in 1.18 build
Post by pythoncoder » Fri Apr 01, 2022 9:46 am
There does seem to be a firmware bug here but I'm unsure how to report it as the maintainers are unlikely to have a suitable IMU.
