how to see module contents?
KJM
Post by KJM » Mon Apr 18, 2022 1:23 am
upythons builtin onewire module is throwing an error
File "ds18x20.py", line 20, in convert_temp
TypeError: function takes 1 positional arguments but 2 were given
This module is either frozen or baked-in not in lib
>>> os.listdir('lib')
['urequests.py']
I'd like to have a peek at ds18x20.py to try to figure out the problem but I can't work out how to do it in the repl? Can't seem to get past
>>> dir(onewire)
['__class__', '__name__', '__file__', 'machine', 'time', 'OneWire', 'DS18X20']
>>> inspect.getsource(onewire)
NameError: name 'inspect' isn't defined
Thoughts on how to see what's in ds18x20.py anybody?
sweetcandysp
Re: how to see module contents?
Post by sweetcandysp » Mon Apr 18, 2022 2:35 am
Do you see them in a scan? I would have thought you would (as adv_type = 3). (If you see them in bluetoothctl then you should see them from MicroPython).
slope 2
Post by Roberthh » Mon Apr 18, 2022 5:48 am
No need to guess, since the source code is available: https://github.com/micropython/micropyt ... ds18x20.py
KJM
Post by KJM » Mon Apr 18, 2022 12:18 pm
Turns out Robert that old 2016 module ['__class__', '__name__', '__file__', 'machine', 'time', 'OneWire', 'DS18X20'] was in the ESP32 flash & was taking import precedence over the baked-in ['__class__', '__name__', '__file__', '_ow', 'OneWireError', 'OneWire'] version of onewire. Once I deleted it my temperature calling routine worked.
Interestingly (to me anyway) if the old 2016 module is in lib it doesn't take import precedence over the baked-in version.
So there is no way to catch a glimpse of baked in module code? Trawling google for examples of how to call something like onewire is tough going when there are multiple versions of onewire floating around, each requiring it's own matching calling routine.
