How to Production Progam and upload system files
PM-TPI
Post by PM-TPI » Mon Apr 18, 2022 8:57 pm
I am try to use Powershell and rshell to Flash and upload files to ESP32 with no success.
2021_production_program.ps1
esptool.py --chip esp32 --port COM13 erase_flash
esptool.py --chip esp32 --port COM13 --baud 921600 write_flash -z --flash_mode dio --flash_freq 40m 0x1000 firmware.bin
rshell -p com13 --buffer-size 512 "cp boot.py /pyboard; cp main.py /pyboard; cp dash.html.gz /pyboard; cp 2021.svg.gz /pyboard"
rshell seems to stop copying at... cp dash.html.gz /pyboard; and starts the boot and main program.
Can rshell copy gzip files ???
Compressed 1888432 bytes to 1178231...
Wrote 1888432 bytes (1178231 compressed) at 0x00001000 in 16.4 seconds (effective 918.6 kbit/s)...
Hash of data verified.
Leaving...
Hard resetting via RTS pin...
Using buffer-size of 512
Connecting to com13 (buffer-size 512)...
Trying to connect to REPL . connected
Retrieving sysname ... esp32
Testing if ubinascii.unhexlify exists ... Y
Retrieving root directories ... /boot.py/
Setting time ... Apr 18, 2022 16:37:33
Evaluating board_name ... pyboard
Retrieving time epoch ... Jan 01, 2000
Copying 'C:\Users\rlsap\OneDrive - GraphicComponents\1-SmartLOG Code\2021-Flash/boot.py' to '/pyboard/boot.py' ...
Copying 'C:\Users\rlsap\OneDrive - GraphicComponents\1-SmartLOG Code\2021-Flash/main.py' to '/pyboard/main.py' ...
b'\r\nin boot.py\r\n\r\npower latched...\r\ntft backlight set...\r\nassertion "atomic_load(&lock->dev[i]) == (intptr_t)NULL" failed: file "/mnt/c/SmartLOG/FW/Build/esp-idf/components/driver/spi_bus_lock.c", line 560, function: spi_bus_deinit_lock\r\n\r\nabort() was called at PC 0x401eebe0 on core 0\r\n\r\nBacktrace:0x40094b81:0x3ffd1460 0x40095169:0x3ffd1480 0x40098df9:0x3ffd14a0 0x401eebe0:0x3ffd1510 0x40192222:0x3ffd1540 0x40191a78:0x3ffd1560 0x400d82e2:0x3ffd1580 0x400d849d:0x3ffd15b0 0x400d86f6:0x3ffd1660 0x400e130d:0x3ffd16c0 0x400e3629:0x3ffd16e0 0x400e5e6e:0x3ffd1700 0x400dd09c:0x3ffd17a0 0x400e3629:0x3ffd17d0 0x400e3652:0x3ffd17f0 0x400ef4a3:0x
I am looking for the bare minimum code need to FLASH and UPLOAD files.
No need for Repl.
Any and all methods welcome !!!!
Re: How to Production Progam and upload system files
Post by dhylands » Tue Apr 19, 2022 12:51 am
I'd recommend that you use --buffer-size=32 when using the ESP32 (and this is now the default with the latest versions of rshell)
If that doesn't work, then try using the --ascii option as well.
PM-TPI
Post by PM-TPI » Tue Apr 19, 2022 1:30 pm
added the --ascii switch and removed baud to run at default 32...
PS C:\Users\rlsap\OneDrive - GraphicComponents\1-SmartLOG Code\2021-Flash>
rshell -p com13 -a "cp boot.py /pyboard; cp main.py /pyboard; cp dash.html.gz /pyboard; cp 2021.svg.gz /pyboard"
Using buffer-size of 32
Connecting to com13 (buffer-size 32)...
Trying to connect to REPL  connected
Setting time ... Apr 19, 2022 09:22:19
starts copying and freezes ???
What now ?
I need to program ~ 20 units to day and > 100 next week, and doing this manually is tough.
Trying to hold a Dupont Pogo in one hand while doing keyboard commands is crazy.
Post by dhylands » Tue Apr 19, 2022 6:00 pm
I'm not sure. This usually means that the UART has dropped a character.
You could try mpremote
Are you running the latest version of rshell? (which is 0.0.31).
PM-TPI
Post by PM-TPI » Tue Apr 19, 2022 7:57 pm
yep...
installed yesterday
PS C:\Users\rlsap\OneDrive - GraphicComponents\1-SmartLOG Code\2021-Flash> rshell --version
0.0.31
using pymaker... no issues
Trying mpremote now...
PM-TPI
Post by PM-TPI » Wed Apr 20, 2022 1:58 pm
So mpremote worked perfect !! Thank YOU Dave !!
mpremote connect COM13 fs cp boot.py main.py dash.html.gz 2021.svg.gz :
But I'm still having an issue with my Powershell script (.ps1)...
The two esptool commands work fine, but mpremote doesn't start.
Any thoughts ??
It appears esptool is not releasing when complete.
