PC python script to run mpremote commands
PM-TPI
Post by PM-TPI » Mon Jun 06, 2022 9:01 pm
So....
from mpremote import main
main.main()
returns...
Connected to MicroPython at COM12
Use Ctrl-] to exit this shell
But how do I run say... the 'mpremoyte ls' command ?
main() takes 0 positional arguments... so how do I pass 'ls' ?
I don't want to use bash scripts.
jahr
Re: PC python script to run mpremote commands
Post by jahr » Tue Jun 07, 2022 8:14 am
I'm using it this way
  def _call_mpremote(self, args):
    args.insert(0, 'mpremote')
    proc = subprocess.Popen(args, stdout=subprocess.PIPE, stderr=subprocess.PIPE, text=True)
      out, err = proc.communicate(timeout=None if self._timeout in (None, 0) else self._timeout)
# etc.
where args are arguments of mpremote.
PM-TPI
Post by PM-TPI » Tue Jun 07, 2022 9:53 am
jahr
Can't we make calls to mpremote directly
without needing to go back out to OS
jahr
Post by jahr » Tue Jun 07, 2022 12:33 pm
jahr
Maybe. I've tried and did not succeeded. IMHO mpremote is not intended to be called as a module and pyboard.py should be used instead. For my use case, the method described was sufficient.
PM-TPI
Post by PM-TPI » Tue Jun 07, 2022 1:02 pm
https://www.youtube.com/watch?v=EVJA01W9ArI
219 views Oct 26, 2021 Damien George instructs us on how to use mpremote
look at 1min 28 sec
Damien didn't go into any detail in using it as a module.
Thank you jahr... subprocess, learn something new everyday.
Post by dhylands » Wed Jun 08, 2022 6:57 pm
You could also just populate sys.argv and then call main.main()
Post by jimmo » Mon Jun 20, 2022 6:20 am
mpremote is built on pyboard.py, and this is designed to be used as a module from your own scripts.
See https://docs.micropython.org/en/latest/ ... rd-library
You can use pyb.fs_ls(), however this will print out to stdout which is probably not what you want. It would be good to extend these libraries to support this use case.
