Restore the original array after Bubble Sort
Soham1087
Post by Soham1087 » Wed Jun 15, 2022 9:40 am
If the given array is [5, 8, 1, 9], after bubble sort, the sorted array will be [1, 5, 8, 9].
Is there a way to restore the original array [5, 8, 1, 9] using the sorted [1, 5, 8, 9]?
Do we have any algorithm for this?
I have tried this
#include <iostream>
#include <algorithm>
int main()
    int test[] = { 5,8,1,9 };
    int index[] = { 0,1,2,3 };
    // perform bubble sort on the data in ascending order
    // utilizing the index array as a guide
    for (int i = 0; i < 4; ++i)
        for (int j = 0; j < 3; ++j)
            // Note the test with respect to the index
            if (test[index[j]] > test[index[j+1]])
                // exchange the indices if item is out-of-order
                std::swap(index[j], index[j+1]);
    // Output results
    std::cout << "sorted: ";
    // Print the sorted array
        std::cout << test[index[i]] << " ";
   // Print the original array
    std::cout << "\noriginal: ";
        std::cout << test[i] << " ";
Output:
sorted: 1 5 8 9
original: 5 8 1 9
Reference - wiki, Scaler
Re: Restore the original array after Bubble Sort
Post by Roberthh » Wed Jun 15, 2022 9:46 am
No, you cannot, since the old content is overwritten and the information about the previous order is lost.
scruss
Post by scruss » Wed Jun 15, 2022 4:05 pm
If you need to step through a list in order without changing it, sorted() will do that:
arr = [5, 8, 1, 9]
print("Before: ", arr)
print("Step through list in order ...")
for i in sorted(arr):
    print(i)
print("After : ", arr)
print("Sort array in place (destructive) ...")
arr.sort()
print("Sorted: ", arr)
Output:
Before:  [5, 8, 1, 9]
1
5
8
9
After :  [5, 8, 1, 9]
Sorted:  [1, 5, 8, 9]
.sort() is a little more efficient than a bubble sort
Post by pythoncoder » Thu Jun 16, 2022 9:07 am
That is the understatement of the year ;) Bubble sort is notoriously slow. Its only merit is that the algorithm is easy to understand.
