read / write png files
Is there any way to read / write png files with micropython?
Re: read / write png files
Of course, like any other file .
Way too less information here.
Where does your graphic data come from?
What is wrong with e.g. https://github.com/Ratfink/micropython- ... ter/png.py (first Google hit when searching "micropython PNG") ?
A few hours of debugging might save you from minutes of reading the documentation!
I want to read / write png files from flash storage. i am able to read png files with https://github.com/Ratfink/micropython- ... ter/png.py but that library does not allow me to write png files.
Just out of curiosity:
Did you try to comment out the Writer class?
I haven't tried that. But why would the author comment it out if it works good.
You didn't answer my question "Where does your graphic data come from?".
Depending upon your application, it might be sufficient to write files using a simpler format (TIFF, GIF) or render the PNG files elsewhere (e.g. in a web browser).
In my case I want to read png file from onboard storage, run some image processing algorithms and write the output back to onboard storage as png file. Then view the output png from pc.
How can i write files in tiff / gif format. Is there a library for that? Also, how can I render png in a web browser without writing a png file?
