I am trying to install (run) BTree.py in MicroPython on the RP2040. This is the chunk of code and it reports syntax error at the third last line "def _build_bulkloaded_branches ...". Can anyone suggest what I missed - after all I am definitely a newbie.
@classmethod
def bulkload(cls, items, order):
tree = object.__new__(cls)
tree.order = order
leaves = tree._build_bulkloaded_leaves(items)
tree._build_bulkloaded_branches(leaves)
return tree
def _build_bulkloaded_leaves(self, items):
minimum = self.order // 2
leaves, seps = [[]], []
for item in items:
if len(leaves[-1]) < self.order:
leaves[-1].append(item)
seps.append(item)
leaves.append([])
if len(leaves[-1]) < minimum and seps:
last_two = leaves[-2] + [seps.pop()] + leaves[-1]
leaves[-2] = last_two[:minimum]
leaves[-1] = last_two[minimum + 1:]
seps.append(last_two[minimum])
return [self.LEAF(self, contents=node) for node in leaves], seps
def _build_bulkloaded_branches(self, (leaves, seps)):
levels = [leaves]
Error running BTree.py on MicroPython
Re: Error running BTree.py on MicroPython
Hi, can you copy-paste the error message that you're seeing?
