Anyone using python websockets to connect to WebREPL?
Posted: Thu Aug 25, 2022 2:27 am
by spierepf
I'm trying to use the python websockets library (
https://websockets.readthedocs.io/en/stable/) to connect to the WebREPL on my ESP32.
However, I keep getting
websockets.exceptions.ConnectionClosedError: sent 1011 (unexpected error) keepalive ping timeout; no close frame received
exceptions when I try to read from the device.
Re: Anyone using python websockets to connect to WebREPL?
Posted: Thu Aug 25, 2022 2:55 am
by bulletmark
I use
websockets-client which works for me with ESP32's.
Posted: Thu Aug 25, 2022 3:22 am
by spierepf
Are you using the raw REPL protocol? And if so, can you post an example? For me, websocket_client just hangs in the same place that websockets throws that exception.
Posted: Thu Aug 25, 2022 3:38 am
by bulletmark
Not sure what you are asking but I have implemented a REPL mode although I don't support raw (Ctrl+A) or paste (Ctrl+E) modes. Can't give a simple example but nothing tricky stands out. I just set a message handler and process each received string.
Posted: Fri Aug 26, 2022 3:14 am
by spierepf
This is the code I'm trying to use to connect:
import pytest
import websocket
from .credentials import WEBREPL_CREDENTIALS
@pytest.fixture
def client():
ws = websocket.WebSocket()
ws.connect(WEBREPL_CREDENTIALS["url"])
assert "Password: " == ws.recv()
ws.send_binary((WEBREPL_CREDENTIALS["password"]+"/r").encode("utf-8"))
print(ws.recv())
def test_eval(client):
pass
However, the call to print(ws.recv()) just hangs, my device never responds to the password.
Any suggestions?
Posted: Fri Aug 26, 2022 3:29 am
by bulletmark
That "/r" should be "\r\n".
Posted: Fri Feb 03, 2023 10:55 am
by ihornehrutsa
# websocket_REPL_test.py
# Install websocket-client:
# pip install websocket-client
CRLF = b"\r\n"
command = b'''
1+1
2+2
PASS = b'' + CRLF
IP = '172.16.11.51'
import websocket
import _thread
in_message = ''
def on_message(ws, message):
print(message, end='')
def on_error(ws, error):
print(error)
def on_close(ws, close_status_code, close_msg):
print("### closed ###")
def on_open(ws):
def run(*args):
#ws.settimeout(20)
ws.send(PASS)
for l in command.splitlines():
cmd = l + CRLF
ws.send(cmd)
time.sleep(2)
ws.close()
print("thread terminating...")
_thread.start_new_thread(run, ())
if __name__ == "__main__":
#websocket.enableTrace(True)
ws = websocket.WebSocketApp("ws://" + IP + ":8266",
on_open=on_open,
on_message=on_message,
on_error=on_error,
on_close=on_close)
ws.run_forever()
