SoftSPI on ESP32
eskimo
SoftSPI on ESP32
Post by eskimo » Fri Sep 02, 2022 8:26 am
Hi
I try to run a sdcard on my M5Stack Core2 (esp32).
I have to use the SoftSPI, due to the given cardreader connection on the M5Stack Core2.
Pins are checked with the documentation of the core2. https://docs.m5stack.com/en/core/core2
Card is formatted with FAT32 and I tried different micro-SD cards with the same result.
The most I got was a very long waiting time and the following error on the REPL.
>>> %Run -c $EDITOR_CONTENT
  File "<stdin>", line 11, in <module>
  File "sdcard.py", line 54, in __init__
  File "sdcard.py", line 87, in init_card
  File "sdcard.py", line 135, in init_card_v2
OSError: timeout waiting for v2 card
Here is my code.... Does anybody see the problem with it or has an advise on how to fix the problem?
Thanks in advance
import sys
from machine import SoftSPI,Pin
import sdcard
import uos
spi =SoftSPI(baudrate=100000,polarity=1,phase=0,sck=Pin(18),mosi=Pin(23),miso=Pin(38))
cs = Pin(4, Pin.OUT, Pin.PULL_UP)
sd = sdcard.SDCard(spi,cs)
time.sleep_ms(10)
uos.mount(sd,"/sd")
time.sleep_ms(10)
file = open("/sd/data.txt", 'w')
file.write("Test Test Test")
file.close()
Re: SoftSPI on ESP32
Post by jimmo » Fri Sep 02, 2022 11:36 am
Can you elaborate on why that is?
I don't think this is likely the problem, but does it work if you try a higher baud rate?
Are you using the latest version of sdcard.py? There were some recent fixes. https://github.com/micropython/micropyt ... /sdcard.py
I notice that your stacktrace says line 135 is where the timeout is raised, but that doesn't match the current version.
eskimo
Post by eskimo » Tue Sep 06, 2022 8:12 am
