Dear community;
I would like to create a abstract class inherit from abc (Abstract Base Class) but I found nothing about lib ABC into micropython, maybe it is simply impossible or I did not search well....
Thank you for your replies and help!!
Abstract class in MicroPython
Re: Abstract class in MicroPython
This forum will be made read-only soon. Please post at GitHub Discussions.
MicroPython doesn't support abstract classes but if you're porting exisiting code that uses ABC, then you can just write an empty ABC class and abstractmethod decorator.
See
https://github.com/micropython/micropyt ... tdlib/abc/
See
Thank for your reply!!
Class name:
Phylum
class MyClass:
i=123
def f(self):
print("correct")
Phylum
class MyClass:
i=123
def f(self):
print("correct")
