Problem getting rshell connected to MicroPython on OSX
cappy2112
Post by cappy2112 » Tue May 03, 2016 3:29 am
I'm able to get the REPL going using screen /dev/tty.usbmodem1412, but screen is really clunky.
I've installed shell but can't get it talking to the same device.
rshell
connect serial /dev/tty.usbmodem1412
Connecting to /dev/tty.usmodem1412 ...
failed to access /dev/tty.usmodem1412
Would someone help?
Re: Problem getting shell connected to MicroPython on OSX
Post by dhylands » Tue May 03, 2016 3:53 am
What's the output of:
ls -l /dev/tty.usbmodem1412
show?
I don't use OSX much. Is there /dev/cu.usbmodem1412 as well?
On my Mac Mini, the pyboad shows as /dev/cu.usbmodem99999 (where 99999 is some number).
cappy2112
Post by cappy2112 » Tue May 03, 2016 4:06 am
dhylands wrote:What's the output of:
show?
Yes. What's the difference between the two?
Should I always use the cu device with MicroPython?
Post by dhylands » Tue May 03, 2016 4:43 am
I didn't know the answer, but found out that this is what makes the difference:
http://stackoverflow.com/questions/8632 ... and-dev-cu
For rshell/pyboard, you definitely want to use /dev/cu.usbmodem*
I don't know what the pyboard USB stack does with DCD. It would probably be possible to make it set DCD in such a way that it would also work, but I'm pretty sure that the code doesn't currently do anything to manage that.
cappy2112
Post by cappy2112 » Tue May 03, 2016 4:49 am
dhylands wrote:I didn't know the answer, but found out that this is what makes the difference:
Very interesting. I've added this to my notes.
Thanks Dave
