I am using latest urequests from micropython-lib.
In some rare cases (once in few hours for requests performed repeatedly every second) I get empty response without any header:
{"AirTemperature":23, "FanRpm":0, "MemoryFree":36960, "MemoryAllocated":20656, "DeviceStartup":false, "Error":null}
b'HTTP/1.1 200 OK\r\n'
b''
File "main.py", line 294, in reportStatus
File "main.py", line 283, in reportStatus
File "/flash/lib/urequests.py", line 108, in put
File "/flash/lib/urequests.py", line 78, in request
ValueError: wrong number of values to unpack
This empty response obviously causes failure of following line from urequests.py:
protover, status, msg = l.split(None, 2)
The server was tested for several days with another client and there was no case of empty response therefore I started suspect my client side (WiPy MicroPython).
Do you have any idea what could cause that there is no response to be read from the socket?
urequests error
Re: urequests error
Empty response means that a client socket was closed, which means server closed it or some networking error occurred. As any networking is by definition non-reliable, such errors are bound to occur, and do occur everywhere (with different probability of course). Sure, the module should be prepared for that too and don't handle it like the above. I'll try to research the best way to handle it.
Awesome MicroPython list
Re: urequests error
Thanks a lot for your effort. I am sure this module will be used widely.
