urequests error
Posted: Sat Jul 30, 2016 7:12 am
I am using latest urequests from micropython-lib.
In some rare cases (once in few hours for requests performed repeatedly every second) I get empty response without any header:
{"AirTemperature":23, "FanRpm":0, "MemoryFree":36960, "MemoryAllocated":20656, "DeviceStartup":false, "Error":null}
b'HTTP/1.1 200 OK\r\n'
b''
File "main.py", line 294, in reportStatus
File "main.py", line 283, in reportStatus
File "/flash/lib/urequests.py", line 108, in put
File "/flash/lib/urequests.py", line 78, in request
ValueError: wrong number of values to unpack
This empty response obviously causes failure of following line from urequests.py:
protover, status, msg = l.split(None, 2)
The server was tested for several days with another client and there was no case of empty response therefore I started suspect my client side (WiPy MicroPython).
Do you have any idea what could cause that there is no response to be read from the socket?
b''
